Arctic Cat EXT 580 HELP!! - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 10 (permalink) Old 11-19-2012, 11:50 AM Thread Starter
Hey guys and gals I just got a 1996 Arctic Cat EXT 583 powder special and someone told me that its a grenader and I dont wanna be in some trail and it goes boom so please let me know ASAP or send me a E-MAIL
oxborough11@hotmail.com THANKS!!
oxborough21 is offline
post #2 of 10 (permalink) Old 11-19-2012, 12:02 PM Thread Starter
Thanks again
post #3 of 10 (permalink) Old 11-19-2012, 12:18 PM
The 580 engine has a history of breaking piston skirts unless properly warmed up every time.
Depending on the miles it has, I would consider freshening the top end with new pistons and rings for peace of mind.
post #4 of 10 (permalink) Old 11-19-2012, 06:50 PM
Quoted: 130 Post(s)
And most of the new pistons have a coated piston skirts! Best to do it before 3500mi and it does grenade!
kccats is offline
post #5 of 10 (permalink) Old 11-19-2012, 08:18 PM
Grudman
Grudman's Avatar
Do the 580 efi have the same problem. I only have 1000 miles on the motor!
Grudman
Grudman is offline
post #6 of 10 (permalink) Old 11-19-2012, 09:38 PM
Quoted: 130 Post(s)
Yep do the top end every 3500 mi!
kccats is offline
post #7 of 10 (permalink) Old 11-21-2012, 10:21 PM
Hey has anyone had a engine code on580ext, 2 long flashes 2 short.. Sled fires and that's about it. Compression is 120psi,, fuel psi is 35
Any help would be appreciated
Cheers
Brett1 is offline
post #8 of 10 (permalink) Old 11-21-2012, 11:11 PM
Grudman
Grudman's Avatar
2 long, 2 short- faulty #2(PTO)injector control circuit in ecu or open or short in circuit to the #2 injector
Grudman
Grudman is offline
post #9 of 10 (permalink) Old 11-21-2012, 11:13 PM
Grudman
Grudman's Avatar
1996 and earlier
1 long & 1 short = Open or short in Throttle Position Sensor
1 long & 3 short = Open or short in intake Air Temp Sensor
1 long & 4 short = Open or short in Engine Coolant Temp Sensor
2 long & 1 short = Faulty #1 mag injector control circuit in ECU or open or short in circuit to the #1 injector
2 long & 2 short = Faulty #2 pto injector control circuit in ECU or open or short in circuit to the #2 injector
4 long & 1 short = open or short in the injector timing sensor
4 long & 2 short = open or short in the ignition timing sensor
1997-On Models
1 flash = Open or shortin Throttle Position Sensor
2 flash = Open or short in Engine Coolant Temp Sensor
3 flash = Open or short in Intake Air Temp Sensor
4 flash = Open or short in the barometric Pressure Sensor
5 flash = Faulty Fuel Injectors
the rest of the codes on found on this forum!
Grudman
Grudman is offline
post #10 of 10 (permalink) Old 11-23-2012, 08:30 AM
Quoted: 130 Post(s)
Did you test at wide open throtle?
kccats is offline
