Carbides for Z570 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-03-2012, 11:43 AM   #1 (permalink)
LivingonaEDGE's Avatar
Carbides for Z570
My friend has either an 02 or 03 Z570 and needs carbides. I was wondering if they have Woody's Slim Jims 6" carbides for this sled. When I look online it only lists that carbide for the ZR models. Do they have the same skis? Will the ZR carbides work?
2002 Polaris Edge 600 XCSP
136" Extension kit with Ripsaw 1.25"
MBRP Can
Powermadd Pivot adapter
4" Riser
2012/2013 - 370 miles
LivingonaEDGE is offline   Reply With Quote
Old 11-03-2012, 06:17 PM   #2 (permalink)
Yep! There are just 2 Cat plastic skis! The bolt patern is almost the same except the back bolt is spaced farther back!
Old 11-04-2012, 05:22 PM   #3 (permalink)
the Z570 will work with the ZR? Or is the Z570 spacing farther back on that ski? Also, if they are different will a ZR ski fit onto a Z570 sled without any modifications
MBRP Can
4" Riser
Old 11-04-2012, 05:46 PM   #4 (permalink)
Rczr600rider's Avatar
If the carbides don't line up, it's pretty easy to drill a new hole in the ski to make them fit. No need to swap skis.
