your thoughts 1999 ZRT 600 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 10-22-2012, 06:03 PM   #1 (permalink)
DANZL550's Avatar
just inquiring about pros and cons about this sled any experience with this sled please let me know. 1999 arctic cat zrt600 ,
2001 yamaha sxr 600
DANZL550 is offline   Reply With Quote
Old 10-22-2012, 07:05 PM   #2 (permalink)
aduck's Avatar
Alot of guys here swear by zrt6's. Pretty dependable.and keep up with the 800's pretty well but being a trip they do have some weight ti them
93 mach1 670
02 rmk 800 162
95 powder special 580
Old 10-22-2012, 07:07 PM   #3 (permalink)
93Wildcat700's Avatar
Pretty nice sled. roughly 120ish HP stock. Depending on the year should have the wider zr a-arms. I bought my buddies after he melted a piston/jug.
As long as you do normal things like keep the jetting correct and regular maintenance it should be fine. depending on miles you may want to consider the water pump eventually.
Its a cool little triple im sure it can be bored out to a 700 too
1993 Wildcat 700 EFI- river runner
2000 ZRT chassis/Wildcat 700 EFI motor swap. Stock lol
93Wildcat700 is offline   Reply With Quote
Old 10-22-2012, 08:08 PM   #4 (permalink)
Prob the best small bore sled! Great suspension, real good power, really fairly light for age and power! Capable of 170hp!
Old 10-22-2012, 09:57 PM   #5 (permalink)
DANZL550's Avatar
Sweet may be picking one up, wow 170hp eh, what you need to achieve that ?
2001 yamaha sxr 600
Old 10-23-2012, 07:47 AM   #6 (permalink)
Porting and pipes, air box and carbs! I believe it was 124 to begin with! Speak with Dale from D&D!
Old 10-23-2012, 04:40 PM   #7 (permalink)
DANZL550's Avatar
Is 100, 90, 100 compression ok or time for a rebuild ? It has 5500 miles
2001 yamaha sxr 600
Old 10-23-2012, 04:53 PM   #8 (permalink)
77zman's Avatar
Rebuild
My ZR is faster then your ZR
77zman is offline   Reply With Quote
Old 10-23-2012, 05:10 PM   #9 (permalink)
DANZL550's Avatar
Is it normal to have a difference of 10 ? Why 90 in the middle
2001 yamaha sxr 600
Old 10-23-2012, 05:19 PM   #10 (permalink)
77zman's Avatar
Its not uncommon to have ten psi differencebut between cylinders. Its just a little to low
Old 10-23-2012, 05:36 PM   #11 (permalink)
aduck's Avatar
I personally rebuild when any piston hits 105-110# its alot cheaper to fix now then when something lets go
93 mach1 670
02 rmk 800 162
Old 10-23-2012, 06:14 PM   #12 (permalink)
Rebuild for sure. My zrt hit about 5000 miles and one of the piston skirts broke off. Those motors are known for that happening at that mileage. That compression is low. After a rebuild and some tuning those zrt 600's are a force to be recond with!!! I still miss mine. If you do buy it I have a few tricks to give you some extra horsepower without spending money with just a little bit of elbow grease!!!
Old 10-23-2012, 06:32 PM   #13 (permalink)
DANZL550's Avatar
How would I know if the skiet broke off ? Also what about the lower end ? I heard they go for some time 10,000 plus ?
2001 yamaha sxr 600
Old 10-23-2012, 08:01 PM   #14 (permalink)
Roof_991's Avatar
if a skirt broke you would know lol. n hell my 580 only had 90 psi and ran great lol
Sent from my SCH-I500 using Snowmobile.com App
Roof_991 is offline   Reply With Quote
Old 10-23-2012, 09:32 PM   #15 (permalink)
To be honest with you I didn't know the skirt broke off until I tore it down for a rebuild. It was a little down on power and the compression was a little low on that cylinder. I got lucky though because the pieces got spit out of the exhaust before it did any damage. Not even a scuff on the cylinder wall. I could see where the pieces made a few laps around the crank but no damage at all. Make sure the guage your using is accurate. It wouldn't hurt to try another guage. I had to trash one a few years ago because it was way off. Like I said thats right at the miles for a top end for that motor. You heard right you should be able to get alot more miles out of the bottem end.
Old 10-23-2012, 09:46 PM   #16 (permalink)
I just fix 'em...
IRONDOG's Avatar
At 5500 miles it needs pistons if it hasn't been done. You will not see much over 115lbs on a fresh top end on the ZRT6 because it has a high exhaust port. Great little engines.
www.snowmobileswapmeet.com
Old 10-24-2012, 07:06 AM   #17 (permalink)
Most ALL 2 strokes will see a benifit from a rebuild at about 3-3500 miles! I can look up a cost for you complete with seals and gaskets!!
Old 10-28-2012, 07:08 PM   #18 (permalink)
LiFeStArTs@40's Avatar
Great sled! No complaints on mine. Pretty damn fast too.
2001 Arctic Cat ZRT600 FOR SALE
2011 ARCTIC CAT F8 SNO PRO LTD
2001 ARCTIC CAT ZR800
LiFeStArTs@40 is offline   Reply With Quote
Old 11-10-2012, 01:49 PM   #19 (permalink)
Dad has a 01 ZRT 600 LE and when I had my 04 F6 Sno Pro and my cousin has a early build F6. That lil ZRT was hard for us to beat in a race. It comes out of the hole like a beast and screams in mid-Rang and Top end
Urban 1000 is offline   Reply With Quote
