ZR 580 tether switch problem - Snowmobile Forum: Your #1 Snowmobile Forum
Old 09-20-2012, 02:23 AM   #1 (permalink)
I have a 96 ZR 580 EFI that was converted to carb from the last owner. I pulled the tether while it was running, it killed it, then it wouldn't start again after I put the tether back on. I ended up bridging the wires that bypass all the other electrical components besides the spark plugs and it worked fine. I want to at least make it so the key works again, the tethers not so important to me. I could probably just wire the key to the ignition and bypass the tether, but I still don't know why it happened only when I pulled the tether when it was running because I had pulled it off when the sled was off and it started after that. I'm guessing there's a short that started when I pulled the tether while it was running. Any thoughts?
Jwbures is offline   Reply With Quote
Old 09-20-2012, 06:03 AM   #2 (permalink)
You can just bypass that switch.
I personally would replace it.
Old 09-20-2012, 07:54 AM   #3 (permalink)
If you loosen the counsel you will see the ign switch and the teather! The 2 wires to the teather can just be unhooked and the 2 wires can just go to the ign switch!
Old 09-20-2012, 02:47 PM   #4 (permalink)
Alright thanks guys, I'll bypass the tether and see what happens. Is it common for those to go bad?
Old 09-20-2012, 03:31 PM   #5 (permalink)
No, it's more likely that the key switch does.
Old 09-21-2012, 08:18 PM   #6 (permalink)
Yep, the teather usualy just needs to be twisted?
Old 09-21-2012, 09:11 PM   #7 (permalink)
I did have one go bad, to get back to the trailer, I had to use a small piece of wood under the tether so that there was adequate pressure on the pressure switch for it to work. I was at wits end until I figured that out. I hate electrical problems. Can't see those dang electrons moving on that wire!
Old 09-21-2012, 09:15 PM   #8 (permalink)
yournytech's Avatar
As mentioned above, I wouldn't bypass a tether; I'd replace it. Search YouTube for "Runaway sled" video... 'nuff said.
yournytech is offline   Reply With Quote
Old 09-22-2012, 12:11 AM   #9 (permalink)
Yeah I'll end up replacing it. Still baffles me as to why it went bad when I pulled it while it was running vs. when it was off. BC_Dan - I tried pushing the tether button down with a screwdriver to make sure that wasn't problem and no dice there.
Old 09-22-2012, 10:03 AM   #10 (permalink)
It's just a bad contact!
