Fuel Injector/Stator issue 97 ZR 580
I have a 1997 Arctic Cat ZR 580 EFI; I had the stator rewound and have to pull it back out and have it done again. I believe I also have an injector issue; when initially started it runs at high RPM for several minutes before it spools down. After running; if you turn it off and attempt to restart, it appears to flood out, if you pull the injector plugs, let it run out of fuel, connect the plug, it starts back up. Or atleast it did until the stator went again. I bought it used for my sons to ride two years ago and have not been able to hardly use it. I have priced out new injectors, however I do not want to spend $320 apiece for them. Does anyone by chance no of another option. I read a thread from another person and it mentioned there is a person South of Morris that possibly works on used injectors; does anyone know who this may be? I had a friend who had a ZR back in 97, I really enjoyed riding it then, not so impressed with the one I have currently. I don't mind working on it, I just am attempting to make a couple of steps forward. I would appreciate any information that can be provided. Thank you in advance.
