1998 ZR600 Water Pump Removal Help - Snowmobile Forum: Your #1 Snowmobile Forum
Old 05-29-2012, 06:36 AM   #1 (permalink)
So I finally tracked down the coolant leak on my sled. It is coming from the bottom of the water pump. Either bad gasket or bad mechanical seal. I figure I will replace both.
I really would like to know what the best way to do the job is... Remove the entire engine or just remove the engine mounting bracket that is in front of the water pump? Can someone who has done this job give me some tips?
Thanks,
Jeff
jdwyk is offline   Reply With Quote
Old 05-29-2012, 05:31 PM   #2 (permalink)
ride till your broke
Renagade's Avatar
well im sure you will get opinions for either way.
id remove engine. but thats me!!!
i did on my formula, and cleand everything
while it was out on bench.
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e-mint!!
Old 05-29-2012, 05:37 PM   #3 (permalink)
If there is a leak it is the mech seal! Pull the motor! And do the crank seals too!
Old 05-29-2012, 07:12 PM   #4 (permalink)
smokingcrater's Avatar
You can have that motor out in under 30 minutes. If you do manage to figure out a way to get to the pump with it in, its going to take you far longer than that.
3) 2004 Yamaha Warrior
4) 2006 Yamaha Nytro
Old 05-29-2012, 09:15 PM   #5 (permalink)
The mech seal kit is about $35.
Old 06-02-2012, 03:28 PM   #6 (permalink)
Well i removed the motor today. Easier than i thought... Took the water pump cover off, someone had done some work on it before i opened it because you could see where they scraped the block with a gasket scraper or flathead screw driver. The o-ring gasket was fine but they added silicone around it which is what i think failed a long with the mechinal seal.
Does anyone have any tips on replacing the seal?
Old 06-03-2012, 10:55 AM   #7 (permalink)
Its tough to get out! Try a sharp small wood chissel To get it to move. And don't forget the ceramic under the inpeller
Old 06-03-2012, 05:44 PM   #8 (permalink)
So the ceramic that is on the impeller, the spring with rubber, and then the piece that is pressed into the crank case? Here is what it looks like after removing the cover. The question i have is what is the piece that looks crimped to the shaft?
1998 ZR600 Water Pump Removal Help-20120602_144747.jpg   1998 ZR600 Water Pump Removal Help-20120602_145204.jpg   1998 ZR600 Water Pump Removal Help-20120602_145145.jpg   1998 ZR600 Water Pump Removal Help-20120602_145210.jpg
Old 06-03-2012, 09:09 PM   #9 (permalink)
The 3rd pic is still the mech seal, take the sharp small wood chisel and remove the metal cup, that is what looks like its crimped to shaft. But you are going to want to remove that shaft as well and buff it atleast! And as I said before this is the best time to repalce both crank seals too!
