tigershark/ thundercat 1000 motor build - Snowmobile Forum: Your #1 Snowmobile Forum
Old 04-30-2012, 11:18 AM   #1 (permalink)
its for a tigershark but its similar the the thundercat motor I built a jet boat with a 1000 tripple motor, long story short that motor is toast and my new one comes with v force reeds cant find any info on if i need to run it richer for the reed setup , dont wanna have to rebuild the second motor or burn it down.
scubapro820 is offline   Reply With Quote
Old 04-30-2012, 01:12 PM   #2 (permalink)
Terrain Dominator
JD8345RT's Avatar
So are you trying to run a Tigershark motor in a Thundercat? Or vice-versa? The TC motor has a balancer shaft, TS motor does not, sled will vibrate pretty bad without it.
1993 Polaris XLT Special
1972 Arctic Cat Panther
Old 04-30-2012, 01:40 PM   #3 (permalink)
No its a ts engine in my boat but someone here should know if v FORCE reeds need carb adjustments to be properly tunedi
Old 04-30-2012, 02:41 PM   #4 (permalink)
Terrain Dominator
JD8345RT's Avatar
Vforce reeds move more air, need more fuel. Jet it fatter.
Old 04-30-2012, 07:18 PM   #5 (permalink)
I built my Tiger shark 1000. They are the same except the heads! Yes with V force jet up!
Old 04-30-2012, 07:20 PM   #6 (permalink)
1 size for ex: 350-360?
Old 05-01-2012, 05:56 PM   #7 (permalink)
Yep and look at your plugs!
Old 05-05-2012, 09:40 AM   #8 (permalink)
Has anyone ever run the v force reeds and actually noticed any difference? Ive read their claims but any review i've read was pretty unsubstantial
Old 05-05-2012, 10:10 AM   #9 (permalink)
When used with a heavily modded motor, the gains are noticeable.
Mostly you will notice crisper throttle response and sharper low end power.
