Hi I have a 95 wildcat efi 700 and it's got good spark and good compression but sounds like its out of time I'm wondering if it's an easy fix or no I've never messed with efi on sleds yet
I pulled the flywheel off and see no visible damage the fuel pump runs when I turn the key on and the battery light comes on on the gauges when I pull it over it backfires and rips the recoil out of my hands
157 primary side 159 mag side Everything else is good from what I can tell great spark good compression but no start I checked for fuel and I have it I even dumped a little gas in the cylinders and it didn't fire
Well with that HIGH of compression, either someone has been into it or it is all carboned up? Since the season is over (for Me anyway) I would drain the anti and pull the heads and jugs!
Check the battery voltage. If it is below 11.5vdc, it can cause starting problems.
The pump will run like it is supposed to, but the ECU will not read the sensor inputs correctly and it will go into "limp mode".
