1995 Arctic Cat ZR700 No Spark - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 12 (permalink) Old 10-17-2011, 01:50 PM Thread Starter
DG88fan's Avatar
I bought this sled last year and roe it about ten times total last year, and it ran perfectly. I fully winterized it and ran it out of fuel for th summer, and today I got the urge to go and fire them up for the upcoming season. I poured in new fresh gas and poured some down the cylinders, and it fired, the next couple times I poured gas down it didnt fire at all. I check for spark, no spark. I think something funny is going on so I check he kill switch and make sure the key was on... Still nothing, so I look at the ignition coil, it looks like the p.o. mounted the coil onto a plastic shroud and ran a ground wire to the frame... I took the wire off and sanded the surfaces thinking the ground got corroded. Nope, no change. I follow the two wires on the ignition coil back to some kind of "box". The p.o. speedie tied his "box" to the resoveour for the cooling system. So my question is, should this "box" be grounded to the frame also. Anyother ideas of things I could possibly check? I have a few pictures of theignition coil placement ad the speedie tied "box" Thanks for the help.
ID:	17338   Click image for larger version
ID:	17339   Click image for larger version
ID:	17340   Click image for larger version
ID:	17341   Click image for larger version
1996 Arctic Cat EXT580
DG88fan is offline
post #2 of 12 (permalink) Old 10-17-2011, 01:58 PM
aduck's Avatar
Quoted: 13 Post(s)
the other box should be your voltage regulator. and it probably went out from the vibration of being loosely secured id find a better place to secure it firmly to.
93 mach1 670
02 rmk 800 162
95 powder special 580
aduck is offline
post #3 of 12 (permalink) Old 10-17-2011, 02:15 PM Thread Starter
DG88fan's Avatar
So a faulty voltage regulator could cause me to have no spark? Any idea of where its suppose to be mounted?
DG88fan is offline
post #4 of 12 (permalink) Old 10-17-2011, 02:48 PM
aduck's Avatar
Quoted: 13 Post(s)
no clue on a cat. but kccats may have a good idea where its suppose to be mounted. if not him there are plenty of darksiders on here.
93 mach1 670
02 rmk 800 162
aduck is offline
post #5 of 12 (permalink) Old 10-17-2011, 03:56 PM
That is the CDI box and needs to be grounded. It is normally mounted on the bulkhead or on the side of the block.
The black one is the VR and is normally mounted on the back of the chain case or the front of the right foot well.
post #6 of 12 (permalink) Old 10-17-2011, 06:25 PM
Quoted: 143 Post(s)
Most likely a kill switch! Try taking the 4 way plug apart! And test for spark! then jumpthe brown and black and retest!
kccats is offline
post #7 of 12 (permalink) Old 10-17-2011, 07:45 PM Thread Starter
DG88fan's Avatar
If the cdi box needed to be grounded, then it wouldn't of ran last season? I havent made any changes since last year. So I'll try the ignition switch tomorrow, also try to ground the box. Ill report back with the results asap.
DG88fan is offline
post #8 of 12 (permalink) Old 10-17-2011, 08:40 PM
aduck's Avatar
Quoted: 13 Post(s)
your cdi is grounded in the pic by the blue wire
93 mach1 670
02 rmk 800 162
aduck is offline
post #9 of 12 (permalink) Old 10-18-2011, 07:07 AM
Quoted: 143 Post(s)
This is THE most common problem of starting a season!
Again START by unplugging the 4 way!
kccats is offline
post #10 of 12 (permalink) Old 10-19-2011, 07:32 AM
Blaine1's Avatar
Probably the TSS or kill switch. Watch the video and bypass yours. You can also meaure the stator ohms easliy:
Wanted: Dead Stators PM me.
Testing Cat triple stators
Jumper wire bypass
Blaine1 is offline
post #11 of 12 (permalink) Old 10-19-2011, 07:33 AM
Blaine1's Avatar
Testing ohms. Your stator is very similar to this one. Your specs are: 160 & 17 ohms.
Jumper wire bypass
Blaine1 is offline
post #12 of 12 (permalink) Old 10-19-2011, 04:05 PM Thread Starter
DG88fan's Avatar
Well went back out to the garage today and checked for spark just for kicks. It had great spark!!!! I didnt even do anything.... Strange, well Im out of fuel to put in them and I can see air running through the hoses, so I guess ill get some tomorrow and try to get her running tomorrow night! Do you guys have any idea why it would be back to being fine again? Thanks for the replies by the way...
DG88fan is offline
