Originally posted by JonCBrand
Im not sure about the clutching other than a D&D helix 120/80 came on the sled. Therse a set of those sheilds for the secondary that smooth the sides to "decrease Drag"
Its got the flat slide and im running 300 mains
Not much else done to it.
Looking into some trail pipes and a hearthrob clutch kit. and some torque arms to keep that engine in line!!!!
Have you had problems with the motor moving around? Mine keep breaking the rear motor mount. First the mount broke, so I built a reinforced one, and then the HARDEND bolt broke, and the third time it pulled the bolt right out of the aluminum so I had to drill it our and retap it to a bigger size. What's yours been doing?
