Old 02-03-2005, 02:48 PM   #1 (permalink)
97 Zrt 800
97 Zrt 800's Avatar
Nothing happening
97 zrt 800. It seems to have spark, and it's fouling plugs but I can't seem to get the thing to run. I had it out on the lake last weekend and I think I sucked a bit of snow. It was bogging out for a bit and then it was running fine. I brought it back home and then I went to start it and it would not run. I cleaned out the carbs and there was a bit of water in the floats. Still there is no firing. I even tried a couple of sets of plugs and no go. Any suggestions that I can try? I did a compression test and two cylinders have about 113psi and the pto has about 95psi. Is that anything to worry about? Anyways any help would be appreciated.
Jonathan
97 Zrt 800 is offline   Reply With Quote
Old 02-03-2005, 03:10 PM   #2 (permalink)
Bulldog
Bulldog's Avatar
That's pretty low compression. If you did suck in some snow you could have wrecked a piston. Compression is "good" above 120 lbs so your pretty low. Good Luck!
2004 Arctic Cat F7
1997 Arctic Cat ZR 580
1972 JD JDX 400
1978 JD Cyclone 340
Bulldog is offline   Reply With Quote
Old 02-03-2005, 05:23 PM   #3 (permalink)
Check the PTO cylinder. 95 is low. But it should still run on the other two cylinders.
