Old 01-31-2005, 11:19 AM   #1 (permalink)
01ZRT600LE
01ZRT600LE's Avatar
Stuck gearbox
Not sure what is happening but when idling the top rotating assy, ie secondary clutch/brake rotor are not spinning. When I give it gas it clamps down on belt but the secondary won't budge. I shut it down and rolled it over on its side and the track won't spin either. If I put it in reverse the track will spin but the top assy still will not budge. I think something is wrong in the gearbox, something is jammed or something failed. Anyone have this experience?
01ZRT600LE is offline   Reply With Quote
Old 01-31-2005, 11:33 AM   #2 (permalink)
hoss
could be jackshaft/driveshaft bearing seized.....or something in the chaincase
hold it to the bar!
hoss is offline   Reply With Quote
Old 01-31-2005, 01:15 PM   #3 (permalink)
Take the chaincase cover off and inspect for damage. It's probably the secondary clutch bearing in the case.
Old 02-03-2005, 07:59 AM   #4 (permalink)
01ZRT600LE
01ZRT600LE's Avatar
OK I will pop the cover off this weekend and give a look see inside.
Old 02-03-2005, 12:41 PM   #5 (permalink)
rgoers
rgoers's Avatar
When I bought my ZL550, the brake pads were seized onto the brake rotor. Showed the same symptoms as you describe...
Oops... re-read your post. A seized brake would not work either direction... If it runs in reverse, it does sound like something in your chaincase.
2000 440 Panther
1980 Jag 3000 F/C
Old 02-07-2005, 03:54 PM   #6 (permalink)
01ZRT600LE
01ZRT600LE's Avatar
So I opened the chain case and both of the reverse gears had teeth missing. So I need to find replacements that aren't going to cost me an arm and a leg. Just one gear new is $165... ouch
Old 02-07-2005, 04:09 PM   #7 (permalink)
eBay maybe, or Al's
Old 02-07-2005, 04:14 PM   #8 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
http://www.hiperf.com/
