97 special efi help!
Ive been runnin a 97 powder special efi for a couple years now and ive got a problem with it i hope someone can help with.
First,,it started second pull every time, but once its been runnin for a while,, the only way to start it was to open the throttle wide open or else it floods right out.
Then it started to develop a bog in the higher rpms and the only way to clear it was to drop the throttle back to idle to get the engine to pick back up
I tried changing coils, plug caps and plugs and still the same problem till last night when i went and tried it out and it started to backfire and miss really bad. The efi module blinks twice every minute if that means anything,, but now it wont even run,,I'm not so sure its a stator problem cus all the electrical was working fine,, so im guessing its either the efi module or a sensor but does anyone have any experience with this problem?
thanks
