no reading from stator? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 15 (permalink) Old 02-02-2011, 12:19 PM Thread Starter
hello,im trying to get spark and have tried jumping brown/black and no luck. when i try to test stator on 95 700zr i have two males and one female but cant seem to get any reading at all.does this mean the stator is bad or should i get some type of reading?
JamesBlondeau is offline
post #2 of 15 (permalink) Old 02-02-2011, 12:37 PM
http://www.snowmobileforum.com/engin...-tos-here.html
post #3 of 15 (permalink) Old 02-02-2011, 12:52 PM Thread Starter
still no spark
thanks,iv'e read and watched all videos but the stators blain1 tests are bad and still give ohm readings.i can't get any readings? when blain tests the ground is not hooked up.because i was thinking mabye my ground wasnt good enough?
post #4 of 15 (permalink) Old 02-02-2011, 01:41 PM Thread Starter
time is slipping away
its just going to have to go to dealership.there isn't much riding time left,the season will be over soon.i don't know what else to do.usually i can fix my sled but this electrical has got me beat.dealership must be cheaper then replacing cdi,coils,etc.
post #5 of 15 (permalink) Old 02-02-2011, 01:55 PM
rgoers's Avatar
Originally Posted by JamesBlondeau View Post
... there isn't much riding time left,the season will be over soon.....
Huh???? Mid-April is still a LONG way off! We're not even half way through the riding season!
2004 Polaris Trail RMK 136
1997 Ski Doo Summit 500
rgoers is offline
post #6 of 15 (permalink) Old 02-02-2011, 02:24 PM Thread Starter
really
i've been riding since november.Yamaha vmax 500.sold it and bought 700zr and havent riden since.lol.never buying a pullstart again.
post #7 of 15 (permalink) Old 02-02-2011, 05:59 PM
Your voltmeter should be set to ohms and you should get 3 different readings. If you don't get any readings at all that means there is a break in the stator and it's not working at all. Replace the stator and keep on riding.
The dealer has never ever ever been cheaper then buying aftermarket and doing it myself. Thats been my experience.
Case450 is offline
post #8 of 15 (permalink) Old 02-02-2011, 07:02 PM Thread Starter
stator no ground wire
thanks for reply.On the stator four prong plug(two yellow brown,black) there is no ground wire coming out.Should there be a ground coming out of plug?The three prong plug going to cdi has seperate ground wire conecting to cdi.
post #9 of 15 (permalink) Old 02-02-2011, 09:25 PM
that harness supplying the cdi is the one you want to be concerned about. do an ohmeter test on it and if all of your readings are zero, then your stator is shot. Blaine1 will rewind it for you for around 200 bucks.
Not to take anything away from Blaine1 but as he told me - "you would be better off finding a used stator somewhere".
Case450 is offline
post #10 of 15 (permalink) Old 02-03-2011, 06:43 AM
Blaine1's Avatar
You can get several types of readings from a stator:
good readings
no readings
good low bad high
bad low good high
higher readings on either the low or high speed
in your case you have no readings which is an easy diagnosis of a bad stator
You have an old style stator where you have the low speed and high speed coils stacked on top of each other. I can rewind it, but in your case as it was in Case 450's experience for that specific stator you can usually buy 2 or 3 used ones for the price of one of my rewinds which is $150. That is not true in all or actually many cases, but it is in your case because that is a common stator. I try to save guys time and $ when i can and that is why I recommend finding a used one in this specific case.
Wanted: Dead Stators PM me.
Testing Cat triple stators
Jumper wire bypass
Blaine1 is offline
post #11 of 15 (permalink) Old 02-03-2011, 06:44 AM
Blaine1's Avatar
Here are the models that use that same stator:
1989 WILDCAT 650 - ELECTRICAL EQUIPMENT/MAGNETO
1989 WILDCAT MOUNTAIN CAT - ELECTRICAL EQUIPMENT/MAGNETO
1990 WILDCAT 650 MOUNTAIN CAT - ELECTRICAL EQUIPMENT/MAGNETO
1990 WILDCAT 650 - ELECTRICAL EQUIPMENT/MAGNETO
1991 WILDCAT 700 MOUNTAIN CAT - ELECTRICAL EQUIPMENT/MAGNETO
1991 WILDCAT 700 - ELECTRICAL EQUIPMENT/MAGNETO
1992 WILDCAT MOUNTAIN CAT - ELECTRICAL EQUIPMENT/MAGNETO
1992 WILDCAT - ELECTRICAL EQUIPMENT/MAGNETO
1993 WILDCAT - ELECTRICAL EQUIPMENT/MAGNETO
1993 WILDCAT MOUNTAIN CAT - ELECTRICAL EQUIPMENT/MAGNETO
1994 ZR 700 - ELECTRICAL EQUIPMENT/MAGNETO
1995 ZR 700 - ELECTRICAL EQUIPMENT/MAGNETO
1995 ZR 400 - MAGNETO
1995 WILDCAT TOURING - ELECTRICAL EQUIPMENT/MAGNETO
1995 ZR 440 - MAGNETO
1996 ZR 580 - MAGNETO
1996 COUGAR 2-UP - MAGNETO
1996 EXT POWDER SPECIAL - MAGNETO
1996 BEARCAT WIDE TRACK - MAGNETO
1996 EXT 580 - MAGNETO
1996 BEARCAT 550 - MAGNETO
1997 COUGAR MOUNTAIN CAT - MAGNETO
1997 PANTHER 550 - MAGNETO
1997 COUGAR - MAGNETO
1997 POWDER SPECIAL - MAGNETO
1997 BEARCAT WIDE TRACK - MAGNETO
1998 COUGAR MOUNTAIN CAT - MAGNETO
1998 BEARCAT WIDE TRACK - MAGNETO
1998 COUGAR DELUXE - MAGNETO
1998 PANTHER 550 - MAGNETO
1998 COUGAR - MAGNETO
1999 PANTHER 550 - MAGNETO
1999 BEARCAT WT - MAGNETO
2000 BEARCAT WIDE TRACK - MAGNETO
2000 ZL 550 ESR - MAGNETO
2000 PANTHER 550 - MAGNETO
2001 ZL 550 - MAGNETO
2001 BEARCAT WIDE TRACK - MAGNETO
2001 PANTHER 550 - MAGNETO
2002 PANTERA 550 - MAGNETO
2002 BEARCAT WIDE TRACK - MAGNETO
2002 ZL 550 - MAGNETO
2003 ZL 550 - MAGNETO
2003 PANTERA 550 - MAGNETO
2004 PANTERA 550 - MAGNETO
2005 PANTERA 550 - MAGNETO
1992 PROWLER SPECIAL - MAGNETO
1992 EXT - MAGNETO
1992 EXT MOUNTAIN CAT - MAGNETO
1992 EXT SPECIAL - MAGNETO
1993 EXT 580 MOUNTAIN CAT - MAGNETO
1993 580ZR - MAGNETO
1993 EXT 550 - MAGNETO
1993 440ZR - MAGNETO
1993 EXT 580 Z - MAGNETO
1994 EXT 580 MOUNTAIN CAT WAVE - MAGNETO
1994 ZR 580 - MAGNETO
1994 CHEETAH 550 - MAGNETO
1994 ZR 440 - MAGNETO
1994 EXT 580 MOUNTAIN CAT - MAGNETO
1994 EXT 580 - MAGNETO
1995 PROWLER 2-UP - MAGNETO
1995 COUGAR MOUNTAIN CAT - MAGNETO
1995 EXT POWDER SPECIAL - MAGNETO
1995 COUGAR - MAGNETO
1995 ZR 580 - MAGNETO
1995 EXT 580 - MAGNETO
1995 BEARCAT 550 - MAGNETO
1996 COUGAR MOUNTAIN CAT - MAGNETO
1996 COUGAR - MAGNETO
Jumper wire bypass
Blaine1 is offline
post #12 of 15 (permalink) Old 02-03-2011, 06:47 AM
Blaine1's Avatar
That was true in your case because you had a common stator and for the price of one of my rewinds you can usually find 2 or 3 used ones. I sent you the long list of sleds that used that same stator and told you if you couldn't find one after a couple of days you could send it to me to rewind. i was just trying to save you some time and $ just like I am for JamesBlondeau.
Jumper wire bypass
Blaine1 is offline
post #13 of 15 (permalink) Old 02-03-2011, 04:21 PM Thread Starter
bad stator
thanks for all the replies! i took off stator today and seen that it was all broken up inside.Around edmonton they are asking $375 for a rewound stator.i looked around and found a guy that was sent the wrong stuff from ebay and has magneto,stator,coil,pick ups,cdi for $250 so i will go get that tonight. should i look to replace anything else or keep the parts and just use stator? again thanks for all the help and should be sledding tonight.ride on!!!
post #14 of 15 (permalink) Old 02-03-2011, 08:02 PM
I get it man...now that i re-read my post it came off with the wrong tone...i knew you meant it like it was cheaper for me to scare up a used one and it was.
I'm sorry if I caused any confusion.
Case450 is offline
post #15 of 15 (permalink) Old 02-03-2011, 08:43 PM
Blaine1's Avatar
No problem...Only a couple months of winter left at the most...let's ride.
Jumper wire bypass
Blaine1 is offline
