Old 01-28-2005, 01:18 PM   #1 (permalink)
phenfer
Unhappy 1996 ZR 440 wont go into forward gear
I have a 1996 arctic cat 440 ZR.
When I put it away last weekend i went from reverse to forward with out holding the brake.
I heard it grind as i have several times before when i didn't hold the brake, my bad.
Now it will go in reverse but not forward. the shaft spins but it won't turn the track.
I'm thinking/hoping that it's just a linkage problem?
I am pretty new to snowmobiling. I have some mechanical ability.
Might this be a simple fix?
Thanks for any help
Paul
phenfer is offline   Reply With Quote
Old 01-28-2005, 01:20 PM   #2 (permalink)
daktruckie99
not truckie or dak...Mike
have you pulled apart the chaincase to check out the gears?
daktruckie99 is offline   Reply With Quote
Old 01-28-2005, 06:35 PM   #3 (permalink)
z71jordan
check teh flywheel key, my yamaha blaster did the same thing after i rebuilt it teh the key was sure enough sheered right off got a new one ran like a champ, might be the gears though i dunno
z71jordan is offline   Reply With Quote
Old 01-28-2005, 07:22 PM   #4 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
check the spring in the chain case
http://www.hiperf.com/
