track is rubbing on heat exchanger - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 13 (permalink) Old 01-16-2011, 10:23 PM Thread Starter
El Tigre Kid's Avatar
Exclamation track is rubbing on heat exchanger
i replaced all my springs and shock on my suspension and put new cog and bearings in and i rode last night and still noticed my track is rubbing on about just a half an inch length on my heat exchanger right in the rear on both side about the 2 idler wheeles, i have been able to get it to stop rubbing before but i had to re adjust it and its still rubbing i tried loosenin and tightening track still rubbing, can someone tell me if i got to adjust track or front springs or something to try to fix this thatd be great
[COLOR="Red"][SIZE="4"][FONT="Comic Sans MS"][I]~``Tyler Brode``~
SRV AND EL TIGRE
The Sleds
-1979 arctic cat el tigre 6000
-1984 yamaha srv 540
My Past sleds
1979 arctic cat jag 3000
1978 arctic cat jag 2000
El Tigre Kid is offline
post #2 of 13 (permalink) Old 01-16-2011, 10:57 PM
is it stock track or has one been put on with deeper lugs? sounds like a lack of clearance and if its in the rear then you can make a drop bracket for you suspension to gain the clearance needed
MontanaCat is offline
post #3 of 13 (permalink) Old 01-16-2011, 11:24 PM Thread Starter
no its all stock, ya i heard i could put a lift on it, but it shouldn't be rubbing its weird cause its right above those 2 idler wheels, the track is getting pleanty of clearance within the top but no clearance on top of those boogie wheels, like its getting way to much pressure, idk
SRV AND EL TIGRE
The Sleds
My Past sleds
post #4 of 13 (permalink) Old 01-16-2011, 11:33 PM
well those wheels are on a fixed shaftso they shouldnt move. is it hitting directly above them or to the rear of them?
post #5 of 13 (permalink) Old 01-17-2011, 09:48 AM Thread Starter
it is hittin to rear of them, i can stick 2 of my fingers thru every hole and there is plenty of clearance but when i get my hand up to that one spot i can't put one finger in between the track and heat exchanger, im gonna try loosening the track some
SRV AND EL TIGRE
The Sleds
My Past sleds
post #6 of 13 (permalink) Old 01-17-2011, 11:25 AM
catpride's Avatar
Id say double check everything is in the right spot, you said you had it all apart and put new in, there are a ton of adjustments that can made check your skid mount holes and see if your in the highest or the lowest, the rear arm can flip over while you had it apart,
97 zr 580 efi
96 zr 580-700 transplant
catpride is offline
post #7 of 13 (permalink) Old 01-17-2011, 01:53 PM Thread Starter
its in the lowest position i just checked, so probably should be in highest so i pushes the skid downward right?
SRV AND EL TIGRE
The Sleds
My Past sleds
post #8 of 13 (permalink) Old 01-17-2011, 02:26 PM
no the upper hole will give less clearance and i think loosening the track will make it worse
post #9 of 13 (permalink) Old 01-17-2011, 02:36 PM Thread Starter
there is only 1 hole it doesnt have 2 holes.
SRV AND EL TIGRE
The Sleds
My Past sleds
post #10 of 13 (permalink) Old 01-17-2011, 02:39 PM
hummm maybe a picture or your suspension where the bogie wheels are mounted might help
post #11 of 13 (permalink) Old 01-17-2011, 09:01 PM
catpride's Avatar
I would take the skid out look it all over make sure everything looks right, check the new springs you put in that they have tension and are installed correctly, then put it back in and see if anything changes. trying to think its been a long time since I worked on a 79,
97 zr 580 efi
catpride is offline
post #12 of 13 (permalink) Old 01-17-2011, 09:06 PM Thread Starter
ok i will, u can tell its been rubbing for a long time, this has just been such a pain in the neck trying to get this to stop rubbing and its a pain putting the skid back in and out so it would be nice to get it right for once.
SRV AND EL TIGRE
The Sleds
My Past sleds
post #13 of 13 (permalink) Old 01-17-2011, 11:01 PM
does it rub all the time or when the suspension compresses
