79 Jag Bogging down
My friend has a 79 Jag. It will run fine for a while, then it will eventually start to bog down. Sometimes you can keep it running by pumping the throttle, then it will be fine for another minute or so. Sometimes it will just die when pumping the throttle. Thought it might have been the fuel filter so we changed it but it does the same thing. Then we thought it was the fuel pump. Changed it and it does the same thing. Changed the plugs, eventually will do the same thing. Figured it might be fouling them, so we changed them AGAIN. Was fine for a few minutes and bogged again. We eventually ran out of plugs, so for whatever reason we decided to just switch them around. Was fine for a little while and again, bogged down. If we just waited without doing anything with the plugs, it would not fire up. If we played with the plugs, it would fire, but not run for long. A Shop told him it is a bad crank seal. If it were, wouldn't the engine just rev out of control from too much air? or would it just bog down because it was pulling too much air instead of an air fuel mix, causing a lean situation? He is running about 32:1 mix. Hes gonna try 40:1. Any ideas anyone?
~S.O.T.M. January 2006~
98' Cat ZR600 EFI Limited Edition
-Black Magic Clutch
-Black Magic HotRod Chip
-Boyesen power reeds
-Unknown Silencer
-Ripsaw track w/144 Woodys
-Geared 1 down, 1 up
-3.5" Ole's angled riser
