Old 01-24-2005, 10:09 PM   #1 (permalink)
need an f9
need an f9's Avatar
f5 tp sensor?
Has anyone adjusted a throttle position sensor on an f5?
need an f9 is offline   Reply With Quote
Old 01-24-2005, 10:39 PM   #2 (permalink)
YamahaVector
YamahaVector's Avatar
no
Loud Pipes Lose Trails!!!
If you're not in a club you are part of the problem!!!
YamahaVector is offline   Reply With Quote
Old 01-24-2005, 11:26 PM   #3 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
what for?
http://www.hiperf.com/
Old 01-25-2005, 01:01 AM   #4 (permalink)
DitchPickle
Firecat Fanatic
DitchPickle's Avatar
Re: f5 tp sensor?
Don't know about the F5, but I know on the F6 and F7 if you adjust the TPS without knowing EXACTLY what you are doing, you are just asking to melt some pistons...
2004 Firecat F6 EFI
DitchPickle is offline   Reply With Quote
Old 01-25-2005, 08:29 AM   #5 (permalink)
need an f9
need an f9's Avatar
I had the carbs off it to sinc them and just go over them. I was wondering if any performance increase could be found by adjusting it. Does it control timing or what?
Old 01-25-2005, 02:47 PM   #6 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
pin gauge, p/n 0644-345
tps adj tool, p/n 0644-299
1. take the carbs off.
2.loosen the idle screw untill it does not touch the throttle lever.
3.open the throttle and insert the pin gauge into the engine side of the carb. pin must be on the tps-side carb. let the slide down to hole the pin gauge in the carb.
4.connect the tps adj tool to the tps, connect a DVOM to the adj tool.
5. compare readings at idle and at wot.
500cc
idle - wot
1.7V- 3.8 and above
6. if these are not the readings replace.
7.apply dielectric grease before re essmble.
