1998 Powder special EFI - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 23 (permalink) Old 01-16-2010, 09:54 PM Thread Starter
I have a 98 Powder special, until today it has ran fine, 2nd pull always. Now it starts idles then dies. Anyone got any clue, full of fresh, fuel plugs only have 30 miles on them.
Thanks
Wes
WesintheRockies is offline
post #2 of 23 (permalink) Old 01-16-2010, 10:47 PM
n00b in training
98zr600's Avatar
Check your stator? pretty common 98 zr problem.
1998 ZR 600 Efi cross country LE
1971 Panther 303
1972 panther 340
98zr600 is offline
post #3 of 23 (permalink) Old 01-17-2010, 08:21 AM
Trouble codes on the ECU?
post #4 of 23 (permalink) Old 01-17-2010, 08:29 AM Thread Starter
Hmmm well I am new to sledding so don't know much about Codes or ECU, Could you tell me a little more?
Last time I owned a sled was in the late 70's it was a 69 Bomb....
post #5 of 23 (permalink) Old 01-17-2010, 08:35 AM
Find the ECU box.
' + objMainFrame.arrApplicationTitle['EN'] + ' -- EMPARTweb*Version 5.2.2* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
On the side of it is a port with an LED.
This should flash once each time it is pulled over. (self diagnostic)
Anything more than once (long and short) is a trouble code.
The duration and sequence (example: short-long-long = 12) would point to a possible component/linkage solution.
post #6 of 23 (permalink) Old 01-17-2010, 08:56 AM Thread Starter
Find the ECU box.
I had to unbolt the ECU on the bottom was a red light it flashes one time when I pull it. I watched the video on how to test the stator but I can't find a 4 plug coming out of the stator.
post #7 of 23 (permalink) Old 01-17-2010, 09:10 AM
n00b in training
98zr600's Avatar
no trouble codes is good, did u watch blaines video on stator testing??
1971 Panther 303
1972 panther 340
98zr600 is offline
post #8 of 23 (permalink) Old 01-17-2010, 09:16 AM Thread Starter
Yes but I can't find a 4 way plug? How do I know if mine is a ZR or something else, it is not a triple I know that. lol also it is not green. Sorry trying to learn
post #9 of 23 (permalink) Old 01-17-2010, 09:18 AM
n00b in training
98zr600's Avatar
post a pic of the sled if possible
1971 Panther 303
1972 panther 340
98zr600 is offline
post #10 of 23 (permalink) Old 01-17-2010, 09:24 AM
n00b in training
98zr600's Avatar
do you see a 3 prong plug that looks triangular?
1971 Panther 303
1972 panther 340
98zr600 is offline
post #11 of 23 (permalink) Old 01-17-2010, 09:36 AM Thread Starter
Well can't figure out how to post a picture, but it was two 3 prong, one is flat and black and has two yellow wires and a brown wire with the brown being hook to a yellow, there is a white plastic plug has 3 wires you might say it is triangular. can I email you a pic of the sled?
post #12 of 23 (permalink) Old 01-17-2010, 09:39 AM
n00b in training
98zr600's Avatar
to post a picture select go advanced for your post message option , then scroll down to additional options and select the attach files tab
1971 Panther 303
1972 panther 340
98zr600 is offline
post #13 of 23 (permalink) Old 01-17-2010, 10:02 AM Thread Starter
98 Powder special
post #14 of 23 (permalink) Old 01-17-2010, 10:03 AM
n00b in training
98zr600's Avatar
thats definitely either a 98 or 99 zr powder special.
1971 Panther 303
1972 panther 340
98zr600 is offline
post #15 of 23 (permalink) Old 01-17-2010, 10:17 AM
The plug with the yellow wires is the lights and such, the other one with the black and brown wires in it is the ignition connections.
post #16 of 23 (permalink) Old 01-17-2010, 10:20 AM Thread Starter
I am thinking the plug with the lite blue wire must be the one.
ID:	11599   Click image for larger version
post #17 of 23 (permalink) Old 01-17-2010, 11:29 AM
Quoted: 138 Post(s)
It idles then dies,it's getting spark!!!!!! Put a fuel presure gauge inline and see if you are getting fuel! Double check the fuel pump fuse and relay!
kccats is offline
post #18 of 23 (permalink) Old 01-17-2010, 03:21 PM Thread Starter
I tested the stator, I couldn't get two of the test to ever stop on a OMHS meter. thinking maybe bad stator?
post #19 of 23 (permalink) Old 01-19-2010, 04:44 AM Thread Starter
Thanks for all the help the stator is bad....
post #20 of 23 (permalink) Old 01-19-2010, 06:21 AM
Blaine1's Avatar
I got here a little late. I know you already figured this out but the connector on the 1998-1999 ZR/ZL 500&600 EFi is the rectangular shaped clear plastic plug. Here are the test specs:
Brown/Green 450 ohms
Brown/Black 495 ohms
Green/Black 45 ohms
Open Ignition: Newer style ignition including the 1998 and newer ZR’s and ZL’s 1998-2002 ZRT 600,800 and 1000
With an open ignition a live wire goes from the ignition system to all of the switches. The switches are normally open, or not making connection, until in the "OFF" position. When in the "OFF" position the switch will ground the ignition wire to the chassis effectively killing the spark. If a connecter becomes 100% disconnected or if a wire gets cut then the switch will no longer turn off the engine but the engine will still start. With the "normally closed" system if a connector comes loose or a wire gets cut the spark will stop until the wiring is repaired completing the circuit again.
Diagnosing no spark, weak spark or intermittent spark issues
The first thing is separating the issue between switches/handlebars/lights or if the issue is in the primary ignition components like the stator, cdi, coils, trigger coil or possibly plugs or plug wires or plug caps.
1. The first thing you want to do is to take the spark plugs out of the cylinder heads, put the spark plugs in the spark plug boots and lay them on the cylinder head bolt away from the cylinder plug hole so they are grounded. If you pull the sled over and the spark plug is over the spark plug hole and it sparks it will ignite so make sure the plugs are not near the spark plug holes when you pull it over
2. Pull the recoil rope and check the spark at the plug. Is there Spark? Is there spark at each spark plug? IS the spark blue (indicating a strong spark) or is it yellow (indicating a “weak” spark).
3. The next step is pretty much the same whether you saw no spark or a weak spark. On the “open” ignition you can simply unplug the 4-prong connector coming from the stator containing the 2 yellow wires. On some EFI sleds you have 3 yellow wires and one non yellow (ground) wire. The extra yellow wire is used for powering your fuel pump. The other 2 yellow wires in the 4-prong connector sends the power to the lights/hand warmers/tachometer. When you unplug this 4-prong connector you are bypassing all of your switches (Throttle Safety Switch, Kill, Tether ect..) and all of your lights, hand warmers ect..in your handlebars. Pull the recoil over and see if you have spark or if the spark is now blue. Carbureted models can be started and run with this 4-prong connector unplugged but you won’t have lights ect..as mentioned above. If you have an EFI, you can only check for spark and it will not start or run with it unplugged. You need it plugged in to power your fuel pump.
4. If you had no spark and by unplugging the 4-prong connector you now have spark, that tells you that you have something shorted out in your hand controls, switches like the tether, throttle safety switch or kill switch. If you had weak spark and now have blue spark it also tells you that you have a short or a problem with one of your switches. The most likely culprit is the TSS or kill switch, There is a 3 prong connector in your handlebars that if you unplug it will bypass your kill and TSS switch and you will only be able to start and turn off your sled with the key. The 3 prong connector is usually not by the handlebars next to where you put your hands but rather just a little bit down the steering shaft about at the point where the console containing the key switch is located. If you’re not sure which connector it is, just follow the one group of wires out of the right handlebar area where the TSS and Kill switch are located down to where the plug is located. There are other plugs by the handlebar on the right side by the thumb throttle containing yellow wires and are for your hand warmers and thumb warmer and do not have anything to do with the TSS or the Kill switch.
5. If after unplugging the 4-plug switch you still do not have spark or the spark is still weak looking this tells you that the problem is in the major ignition components like the stator, coils, cdi spark plugs, spark plug wires or trigger coil.
6. The first thing to check are the connections from the stator to the cdi. Make sure all connections are free of moisture, are tight and use dielectric grease on it. Check the ground. You should have a ground wire coming from your stator and your CDI/ECU box. Make sure the ground is clean, tight and that the ground wires are not broken. Sometimes the ground wire is pinched and broken inside the eyelet connection and is making only intermittent if any connection. Some older model Arctic Cats have the ground up closer to the handle bars on what some would consider the “firewall” of the sled and they rust/corrode badly.
7. If all connections are solid and the ground looks good then you have to start electrically checking components. Most of the twin trigger coils are supposed to ohm out at 90 or so ohms. Triples are usually 175 ohms. View my “testing a pulser/trigger coil” video to see how to test it. It is a quick test. The frustrating part about the trigger coil is that it can test good, but still be bad.
8. Next you want to test the stator itself. View my “How to test a stator” video to see how to do it. Triple cats and ZR/ZL 500/600 carb sleds have the 4 prong connector. The ZR/ZL 500/600’s have the clear 3 prong rectangular plug and many of the 580’s have a triangular plug.
9. If you have no spark and your trigger tests ok and your stator tests ok then we may be looking at a secondary coil issue. This condition usually causes a miss or it sputters at higher rpms. The coils can have a couple of issues with them. The first thing you want to do is make sure the spark plug caps are on tight. They just screw on and off the spark plug wire. Many times the best thing to do as long as your wires are long enough is to unscrew the spark plug caps, trim a ˝ inch off the end of the wire and then screw the spark plug cap back on. Also, on some coils you can unscrew the wire from the coil itself and do the same thing. Trim off about a ˝ inch and screw it back on the coil. I had 2 sets of coils go “bad” on my sled and come to find out it was just the spark plug wires were a bit warn at their ends and after I trimmed them and screwed them back together they ran perfect. Be warned though that I did have one wire that would not unscrew from a coil no matter how hard I tried to turn it and I ended up just tearing the spark plug wire. Also, always check the spark plug gap and set it to the correct spec for that plug. I have seen plugs with the gap set too small on them making the motor run poorly.
As far as putting the coil wires back on here is a general rule of thumb for Cats:
Most sleds fire all the plugs at the same time, multiple times per revolution. A twin will fire both wires twice each revolution, a triple three times (once per 120 degrees). One of the pulses fires the plug to ignite the fuel/air mix, the other times the pulses are "lost" as the plug fires with the piston not ready for the fuel to burn.
10. If you have no spark and your trigger tests ok, your stator tests ok and you have tried a new set of coils then we’re possibly looking at a bad CDI box. There is no real good way to test the CDI other than swapping the box out with a known good CDI box.
11. Specificly on Battery EFI sleds here is another thing to check. This was found on a 1996 EXT EFI: There are 2 relays on the back of the ecu. 1 is for the spark and 1 for the fuel pump.
12. Also, bad reeds on a sled will cause it to back fire and run poorly acting like it is an electrical issue.
13. Sled won’t shut off condition: I have seen a few things cause this. First off it is usually a bad ground/broken ground wire. Sometimes it is moisture in the connector. I had to disconnect my TSS/Kill switch the day my kill switch got moisture in it and my sled wouldn’t shut off. You could have a cdi with an internal short. Also, a bad stator can cause a sled to not shut off.
14. Other issues/symptoms that I have seen/read related to a no spark/Weak Spark/Wet Plugs issue:
A. A guy bought a used sled with the wrong flywheel on it.
B. Frayed wires somewhere in the wiring harness or under the seat were causing a short
C. Guy said sled was only running on one cylinder. He could remove one spark plug wire and it didn’t effect the way the sled ran. His low side coil on his stator read 360 ohms and it should have measured 450 ohms. His low side coil was dying.
D. It kept fowling plugs left and right. The guy before me ran ethanol, and never told me. This was on an EFI sled.
E. Hood harness was routed between rewind/stator housing and frame and had 4 wires smashed. Repaired wires and ran good.
F. Got it running again tapped the ECU and died. Pulled the ECU cover off and found some corrosion
G. I noticed some wires running to the carbs that were rubbing against the jack shaft (Shaft going from secondary clutch to the top sprocket in the chain case). After rewrapping/rerouting the wires it ran great
H. Bolt for the recoil cup broke off and hit the trigger coil, bent the bracket slightly and gave it too much air gap
I. Oil Injection turned up too high
J. Fuel Lines hooked up backwards
K. I saw a motor where the jetting was way too lean. The sled would start and idle but if you pinned the throttle the sled would bog and quit running. By using the choke we were able to determine that it ran better when you hit the throttle. We jetted up and it ran good.
Wanted: Dead Stators PM me.
Testing Cat triple stators
Jumper wire bypass
Blaine1 is offline
