Old 11-27-2004, 01:46 PM   #1 (permalink)
z71jordan
what lube should i use?
What lube should i use for the chaincase? or is there any other things i can do to my sled to get it ready for snow? ive already changed the plugs, antifreeze, tightend track,cleaned teh carbs. anything else i just got this sled so im wanting to get it all ready for snow thanks
z71jordan is offline   Reply With Quote
Old 11-27-2004, 10:37 PM   #2 (permalink)
need an f9
need an f9's Avatar
straight 30 weight oil is what i've always used.
need an f9 is offline   Reply With Quote
Old 11-28-2004, 07:22 AM   #3 (permalink)
There are usually grease fittings on the front/rear suspensions and steering linkage.
Old 11-28-2004, 12:13 PM   #4 (permalink)
Buck80F7
Buck80F7's Avatar
check your belt, check all suspension bolts. for chaincase lube i would go with KLOTZ chaincase lube. It has a lot of graphite in it. its good stuff. If you cant find it, go with the amsoil.
Buck80F7 is offline   Reply With Quote
Old 11-28-2004, 05:22 PM   #5 (permalink)
That's what I use also, Klotz synthetic. Chains are UNWORN after a ton of use.
