97 ZL440 crank seals, do I need to split the case? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 10 (permalink) Old 11-24-2009, 06:24 AM Thread Starter
Hi again guys, I am considering a 97 ZL440 LC as a second machine, the woman that owns it doesn't have much knowledge of the sled other than it had a piston changed 2 years ago. It has 5000 miles on it, looks good but I know from experience what can be hidden inside the engine/suspension etc. If I buy the machine, I would rebuild top end immediately, my question is, if I find a leaking crank seal, is this an easy fix or do I need to split the crank case? As always, your assistance is greatly appreciated.
kingston_rider is offline
post #2 of 10 (permalink) Old 11-24-2009, 06:53 AM
Quoted: 143 Post(s)
Yep the only reason to have to pull the motor! It really isn't a major major deal, just alot of time! But then it's worth it!
kccats is offline
post #3 of 10 (permalink) Old 11-24-2009, 07:12 AM Thread Starter
That sucks, I don't have the tools to split the case, roughly how much would it cost to have it done if I pulled the motor?
post #4 of 10 (permalink) Old 11-24-2009, 12:02 PM
Just splitting the case to change seals can be done with regular tools. You will need to have the clutch off and to pull the flywheel as well.
Those are the only special tools needed, clutch and flywheel pullers.
post #5 of 10 (permalink) Old 11-24-2009, 05:43 PM Thread Starter
Really, I was under the impression that the two halves of the crankcase are pressed together and special tools were needed to get it apart and to reassemble it. So they come apart fairly easily then?
post #6 of 10 (permalink) Old 11-24-2009, 05:52 PM
You may be thinking about the crankshaft... Those are 2 piece pressed together and a special tool is required.
COOKSTER is offline
post #7 of 10 (permalink) Old 11-24-2009, 05:55 PM Thread Starter
Could be, never had a sled bottom end apart before, so the crank seals wouldn't be that big a deal. Do you have to split the crank to do the crank bearings?
post #8 of 10 (permalink) Old 11-25-2009, 09:48 AM
Yep.
post #9 of 10 (permalink) Old 11-25-2009, 09:51 AM Thread Starter
Thks RJ
post #10 of 10 (permalink) Old 11-25-2009, 05:01 PM
Quoted: 143 Post(s)
It is very straight forward, just take your time!
kccats is offline
