hi the motor is stock, but i,m going to rebuild it from the ground up, i am planning on putting a 2stroke pipe on it from an kx 250 i have laying around to see if that will give some more hp also, right now i have a mikuni carb on it from an 81 skidoo 9500 blizzard it had twin carbs on it, i got an intake boot from an late 80,s yammaha engine. I have to
check he size of that carb. The motor seems to run alright i mixed the gyas a little richer then normal, so i woundn,t run to lean and do some damage. when i got the sled the gauge said it only had 840 miles on it. thanks for any help.
