11-06-2009, 08:09 PM
Firecat Long Track conversion
FYI dont let anyone tell yo you cannot long track a firecat sled. I just completeed my 2003 f7 long track conversion from stock 128" to 144" for a cost of $180. i bought a 144"x15" track off ebay for $80 delivered with 2 inch lugs made by campolast. i used a set of snowpro extensions that were for a 144"-153" track. i spend 6 hours with a file to make them fit on my stock rails. the wheel spacers had to be cut a 1/4" off both sides since the extensions were 1/4" thiker than factor. i cut 5/8" off both sides of the track and it fit right in. i had to add 8" of heater hose to each side and move the heat exchanger back an additional 8" pictures coming soon when i get the camera developed!!!!
TOYS:
500 HP 94 Dodge Ram Cummins Turbo Diesel
03 Arctic cat Firecat 700 144" custom track
1948 Chevy 5ton PTO Dump Truck
2004 Kawaskai Brute Force 650 4x4
1979 19' Silverline skiboat w/ 350 Chevy inboard
11-06-2009, 08:32 PM
XTBX (Anthony)
hey nice job! gotta be creative these days.
Winter:
2006 Arctic Cat Crossfire 600 EFI 136" MINE!
1999 Ski-Doo Mach 1 Triple 700
2002 Polaris Edge X 800
2001 Arctic Cat ZR 600 EFI
1989 Yamaha SRV 540
Summer:
1999 Polaris Trailblazer 250 Quad
2004 Yamaha Wolverine 350 4x4 ATV
2001 Caravelle Interceptor 21' Boat
Past Machines
2000 Ski-Doo Formula Deluxe 380-9/29/09
She will be missed
1991 Suzuki LT 80-9/08
1990 Yamaha Sno Scoot-2007
1996 Larson 16' Bowrider-2007
www.snobusters.com
LET....IT....SNOW!!
11-06-2009, 10:50 PM
ya no kidding, it helps being a diesel mechanic, that and knowing how to weld and mechine stuff, it turned out awsome
TOYS:
11-07-2009, 08:09 AM
Yep as I told another guy, that you would have to MAKE a track! Kool! Lets see some pics!
11-07-2009, 06:41 PM
Braaaaaaaaap
There were a few tracks kicking around with a deep lug made by camoplast, already the 13.5'' wide, but they only made a certain few, not too many.
2008 Cat snopro 600 mod
2005 F7 SnoPro Team Edition BMP Valve Spacers, ODS Clutch Kit, Shaved Secondary (by ODS), 153 StudBoys, 8'' riser, Fly Bars/Hooks, Flyscreen, Black Lens Covers
2005 Renegade 600 H.O.-Dads
11-09-2009, 11:31 PM
ill get some pictures when were done. we had to pull the track again to drop the chassis a 1/2" because the 2 inch lugs are rubbing in the underneath of the tunnel.
TOYS:
11-10-2009, 08:16 AM
You might even need to go to a smaller drivers too!
11-10-2009, 10:22 AM
why smaller drivers?
TOYS:
11-10-2009, 10:44 AM
To give enough clearance for the lugs at the bulkhead.
11-12-2009, 12:07 AM
i talked to the boys at arctic cat today the track is barely skimming the bulk head of the tunnel just enough to notice. were going to file a tad off the existing drivers to make it clear
TOYS:
11-12-2009, 07:10 AM
NO!! Why would you even think that filling a driver would help? You have to have atleast enough room to put your hand between the track and the cooler! At speed that track almost blows up! I don't know who told you to cut a driver, but that is crazy! If you are going threw all this do it right! Get a set of smaller drivers! I would think you have 9 tooth? Go to 8! Regear if you want too!
11-12-2009, 08:32 AM
The centrifugal force of the rotating track causes it to "balloon out" at speed.
You need the smaller drivers to allow for this or you will be jamming the track in there which will cause all sorts of other problems.
Use a smaller driver and then go one tooth smaller on the bottom gear in the drop case.
11-12-2009, 10:46 AM
i do jave that much room at the front to stick my hand threw it its at the top of the tunnel is were its barely hitting
TOYS:
11-12-2009, 11:04 AM
were would i find smaller drivers and gear?
TOYS:
11-12-2009, 11:08 AM
HPE, or any of the online stores should have them, even Tracks USA should have them.
11-12-2009, 09:49 PM
i went ahead and bit the bullet today my driver is a 10 tooth driver, i ordered a set of 9 tooth drivers with anti-ratchets. im gunna have them pressed on tomarrow
TOYS:
11-13-2009, 07:47 AM
With your drive shaft out, take a hack saw and make a mark on each side of the existing drivers! When pressing new on be sure to match the clocking arrows! Another thing is with the anti ratchets you need to make clearence on the rail tips (maybe not with the 9's) and the track has to be open every window!
11-13-2009, 10:36 AM
the track is open every window i noticed that the track that was on the sled when i bought it wasnt but this camoplast i have is, do i have to cut the rail tips down or just take the plastic cap off? im having arctic cat put them on today
TOYS:
11-13-2009, 10:43 AM
#19 (permalink)
Do not remove the caps, they are there to prevent the rails from stabbing the track.
11-13-2009, 10:47 AM
#20 (permalink)
how would i shorthen them if the antiratchets hit. i dont believe they will hit since i lowered the entire chasis down 3/4"
TOYS:
