Originally Posted by kccats
Did you take the tenssioner off? With the chain off hold it up and see how much it rainbows! It should arch about an inch or so! If the chain has streched it could be that the adjuster is out of reach! The chain should be tight and roller not turn! There shouls be just a slight movement on the straight side!
What I did was I got the manual adjuster bolt! It is just that! There is a hex plug in the front of the chain case, remove it and then there is a hex bushing that is taped! Then the bolt goes threw it and pushes against the roller!
Yes I have had the tensioner off a few times. The chain does not arch at all and when installed it is far from straight allowing I believe for the chain tensioner to be to far off the block hence maybe breaking the spring when the roller bracket twisted downward. So I take it then my model already has the threaded hex bushing for the bolt manual adjuster ?
Your info has been of great help and later today I am going to check it out closely. I think now from what I have seen the upper sprocket/gear and and chain are so warn out it caused the tensioner to be to far off the block . I am going to buy both of these and then check it again and hopefully figure it out. I may eventually still change over to the manual design though.
Do you know under so called normal operating conditions how long a sprocket and chain should last takin into account the operational mode and regualar changes of Oil. I know this sled was bought from a guy who knows little and does little to anything he drives as far as maintenance goes. The dropcase was almost dry and the drain plug was loose and missing the fiber gasket probably allowing it to leak for a long time. I was considering maybe this kind of neglect created the heating/wearing out of the parts so fast. The sled has only just under 14.000 KM. we only put about 150 KM on it since we bought it last season and had to park it. Other then this, it runs very well and has plenty of power all the way around.
Thanks again.
