Triples can easily overheat the center cylinder, this is a sign of pending engine failure. Old fuel or leaned out carbs can cause detonation which will chew up your pistons till it blows apart. The center piston shows signs first as heat builds up easier there. If they are just small dents pistons will be fine as long as you fix the dirty carbs ect. If they are chips the damaged parts have to be replaced also.
Run it and risk totaling the engine.
The path less taken has thy best powder!
