Circle-Square-Triangle Ecu??????
I'm only asking cause I'm curious............... I am rebuilding a wrecked 06 F7, and in the process of the rebuild, I found out my ecu (square) was bad , and had both ears broke off. I took my neighbors off and put it on mine and it ran fine (his is a triangle). Out of luck I found a used one that is the exact same part number as mine, and is a square, and my sled lives again.............Now my question, What is the difference between the three? Is the Timing set differentlly? I'm just curious.
