hey guys,hope everyone is doing good! i still have a problem from last year? that no one could seem to answer?? ok just to get this out of the way, i checked cables, carb adjustments,checked for air leaks everything is right! what it is doing is it idles high and the apv valves keep opening and closing? if i unplug the tps on the carbs it idles fine and the valves stop opening and only open when i give it gas? it runs fine with out the tps plugged in?idles perfect as soon as i plug tps in it idles right up to 2500-3000 again? any help would be greatly appreciated! i am about ready to take it to the stealer! please help!!
