It could be as simple as the spider nut coming loose and making noise, to as bad as needing a complete rebuild. How many miles are on the sled? It may be less money to find a used primary compared to buying the tools to do the job yourself. Or you can send the primary off to have it rebuilt and balanced, there are a lot of reputable places that do good work.
It is definitely something to be concerned about, they do come apart, and they can really do some damage to the sled and you...
If you can get the primary on the bench, remove the cover and spring and then you should be able to diagnose where the metal to metal contact is coming from. Then you will know more about which way to proceed.
