drive bearing - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 9 (permalink) Old 10-17-2009, 01:18 PM Thread Starter
AC Rider's Avatar
drive bearing
where exactly is this located? How do i get to it, and hard is it to get to? I wanna replace that little speedo key, how hard is that to replace? Id like to get that done today, so some advice would be great, thx
and to replace the speedo key, do i have to lossen the track and do all tht stuff? If thts the case, i mite as well just replace the bearing.... its funny how polaris doesnt see, to have any of these problems.. now i rememebr why my name is polaris rider
10/11 season: 1014 miles
My sled:
03 z440 sno pro w/ 3000 miles
-Fresh Top End
-Rejetted
-white handguards
-4 inch riser
-1.375 inch track
rest of the fleet:
2003 polaris classic 340 3000 miles(FS)-2003 polaris indy xc 500 2200 miles(FS)-2000 polaris xc 700 7000 miles-2003 arctic cat zl 600 3200 miles-1999 arctic cat zl500 4500 milesSOLD
AC Rider is offline
post #2 of 9 (permalink) Old 10-17-2009, 02:03 PM Thread Starter
AC Rider's Avatar
is the PTO side bearing responsible for the speedo not working? Ive been lookinat my sled all day, wheres the bearing at? I posted a pic of wat i think it is.. let me kno if im rite
Name:	arctic cat zl 011.jpg
My sled:
-Fresh Top End
-Rejetted
-white handguards
-4 inch riser
-1.375 inch track
rest of the fleet:
AC Rider is offline
post #3 of 9 (permalink) Old 10-17-2009, 02:39 PM
JDS
JDS's Avatar
To get to the speedo key, you first need to remove the belt. Under the secondary clutch, you will find a right angle adapter that the speedometer cable goes to. Take off the 3 nuts that hold the adapter on(I think they're 1/2"). The speedo key goes in the end of the shaft that will now be exposed, and the other half is in the speedo adapter. If it's broken, you can use a needle to fish it out. While you have the adapter off, wiggle the end of the shaft to see if the drive bearing is all right.
If the drive bearing is bad, you will need to loosen the track, take the chain case apart, and replace the bearings on both ends of the driveshaft.
JD
____________
2008 Polaris RMK 600-155"
JDS is offline
post #4 of 9 (permalink) Old 10-17-2009, 02:43 PM Thread Starter
AC Rider's Avatar
Thx alot JD.. i plan on replacing the bearing(s) no matter wat, even if they seem fine... cats seem to loose there bearings at around 3k, so i figure this preventative maintance will save me from some expensive repairs down the line
My sled:
-Fresh Top End
-Rejetted
-white handguards
-4 inch riser
-1.375 inch track
rest of the fleet:
AC Rider is offline
post #5 of 9 (permalink) Old 10-17-2009, 06:57 PM
Quoted: 143 Post(s)
Check the how to section a very good step by step!
kccats is offline
post #6 of 9 (permalink) Old 10-17-2009, 08:11 PM Thread Starter
AC Rider's Avatar
well, just foudn out the speedo works.. it was just a little stuck, after i punched it for a few secs it kicked rite in and now is workin greatt
My sled:
-Fresh Top End
-Rejetted
-white handguards
-4 inch riser
-1.375 inch track
rest of the fleet:
AC Rider is offline
post #7 of 9 (permalink) Old 10-17-2009, 11:34 PM
FORGET WORK- I WANNA PLAY
TCOLLINS's Avatar
check cable it might be a little twisted by the key and may eventually break??
1998 Polaris Indy 500
1996 Yamaha Vmax 600
1991 Yamaha Phazer II48
1986 Yamaha SRV 540*Freebee*
TCOLLINS is offline
post #8 of 9 (permalink) Old 10-18-2009, 09:14 AM Thread Starter
AC Rider's Avatar
will do, thx for the heads up tcollins
My sled:
-Fresh Top End
-Rejetted
-white handguards
-4 inch riser
-1.375 inch track
rest of the fleet:
AC Rider is offline
post #9 of 9 (permalink) Old 10-19-2009, 05:40 AM
Blaine1's Avatar
That is the #1 bearing that goes out on the Cat sleds. Keep it greased if you have a zert. If you don't, make sure the replacement bearing is able to be greased.
Blaine1 is offline
