Old 06-29-2009, 09:48 PM   #1 (permalink)
acf7efi
head?
hey does anyone know if i take off the head on my f7 will i need a new gasket?
acf7efi is offline   Reply With Quote
Old 06-29-2009, 10:02 PM   #2 (permalink)
BC_Dan
Welcome to the forum!
The seal from the head to the cylinder uses two rubber O-rings. It's been my experience that trying to reuse the O-rings usually results in a leak. I would use new ones., but you may be luckier than me
Old 06-30-2009, 07:29 AM   #3 (permalink)
Definitely replace the O-rings. They are like 6 bucks. Well worth the grief of trying to reuse the old ones. Welcome aboard!
Old 06-30-2009, 06:42 PM   #4 (permalink)
acf7efi
alright thanks alot guys, i hear lots of good information on this site.
Old 06-30-2009, 09:45 PM   #5 (permalink)
DFickel
DFickel's Avatar
ya def always replace gaskets and seals when takin off head, and if u dont mind askin, why u takin the head off? problems??
FDRAGONS, TUNNIN FORKS, AND BEES CANT KILL THEM CATS!
DFickel is offline   Reply With Quote
Old 07-01-2009, 03:07 PM   #6 (permalink)
acf7efi
because the f7 has over 10205 kilometers and i would like to see the condition of the piston and head.i took off the Y pipe and took a pic. what do you guys think i should do? it has some scratches on the piston...... !!
hope u can see the picture
Old 07-01-2009, 03:51 PM   #7 (permalink)
Some scratching of the piston skirt is normal.
Unless the compression is low (>100psi), you should have no need to open it up.
Old 07-01-2009, 04:07 PM   #8 (permalink)
acf7efi
piston picture by acf7efi - Photobucket
Old 07-01-2009, 06:09 PM   #9 (permalink)
Yep, normal scoring. Shows that he needed to allow a longer warm up time though.
Old 07-01-2009, 08:44 PM   #10 (permalink)
JheLrey
TRH- Troll Raising Hell
JheLrey's Avatar
Misleading title....
Old 07-03-2009, 09:24 PM   #11 (permalink)
supercatzr500
Definetly change them when the motor heats up they expand and when it cools they stay expanded so when you take the head off they will pop out and will not fit back in.
supercatzr500 is offline   Reply With Quote
Old 07-06-2009, 07:50 AM   #12 (permalink)
kccats
Looks like a bit of blow by! For the cost of a set of rings and gaskets, I would atleast freshen the motor! I personally would do pistons too! The cost to do is alot cheaper then once it blows up! And you got plenty of time!!! I would also since you're into it, clean up the transfere ports too!
