Originally Posted by kccats
Start with the simple stuf first! Unplug the 4way coming out of the engine, test! Then put a jumper from the black to the brown, test! This will bypass all the kills! If you get spark you know it's just a kill! If not then look at the low voltage side of the coils and then the coils and last of all the CDI and Or the stator!
i tried but it lookes to me the brown is a ground and the black looks to go to the cdi maby im on the wrong wire harness the other side of the plug is 3 brown in one and i think a single black, im not much of an electricion i have crossed a few different ones and still no fire and it was working so good minutes before maby i have the wrong wires ????
