97 ZR 440 rebuild ??? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-24-2009, 11:06 PM   #1 (permalink)
Angry 97 ZR 440 rebuild ???
ok i bought this sled just the other day and only put 6 miles on it total and then the right piston blew out the outer edge basicly is gone on about an inch of the piston, the cylinder is fine and there isnt any scratch's on side of piston, so my ??? is how do i make sure the bottom end is free of shavings or chunks ide like to keep the motor in the sled any ideas???
playrpaco is offline   Reply With Quote
Old 12-28-2012, 06:38 PM   #2 (permalink)
alexk243's Avatar
To be sure you would have to split the case and clean it out to be sure, but if it lost as much as you said it lost I think you run the risk of further damage to the new piston if you dont get everything out.
1987 Yamaha Phazer 480cc
alexk243 is offline   Reply With Quote
Old 12-28-2012, 06:57 PM   #3 (permalink)
I would clean it out by taking it apart but you could take the cylinders off and stick a tiny magnet Fortin in there and fish the peices out
Sent from my H866C using Snowmobile.com App
indytriumph600 is offline   Reply With Quote
Old 12-28-2012, 07:10 PM   #4 (permalink)
Unless you have invented an Alum magnet, that wont help!
You need to find out WHY it melted down Is there an air leak? Were the carbs Not cleaned? Do you need new seals? Did it over heat? No oil?
Old 12-29-2012, 11:52 AM   #5 (permalink)
alexk243's Avatar
And if an air leak is the case, it wouldent hurt to slit the case and reseal it.
Old 12-30-2012, 06:16 AM   #6 (permalink)
Top end and complete gasket set will be about $200 or less!
