93 wildcat 700 efi - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 24 (permalink) Old 01-04-2009, 04:08 PM Thread Starter
93 wildcat 700 efi
i have a 93 wildcat 700 efi all of the power i get is at half throttle if i give it full throttle it boggs out . what might my problem be. thanks in advance for the help.
dwayne
Last edited by dwayne30; 01-04-2009 at 04:50 PM. Reason: didn't like the title name no seemed to be responding
dwayne30 is offline
post #2 of 24 (permalink) Old 01-04-2009, 04:20 PM
articcatguy420's Avatar
have you tried cleaning the carbs
articcatguy420 is offline
post #3 of 24 (permalink) Old 01-04-2009, 04:25 PM Thread Starter
no its fuel injected
dwayne30 is offline
post #4 of 24 (permalink) Old 01-04-2009, 05:30 PM
well im not to familier with fuel injected but have you tried the fuel pump cause it sounds like its not gettin the fuel it should...
post #5 of 24 (permalink) Old 01-04-2009, 06:02 PM Thread Starter
i agree its definently starving for fuel i will have to try the fuel pump thanks
dwayne30 is offline
post #6 of 24 (permalink) Old 01-04-2009, 07:32 PM
I have a '94 700 EFI doing basically the same thing. It likes to foul the plugs. Possible oil foul. I have yet to go through the fuel system, but it could be anything from a dirty injector to the pump or sensor sticking. One of these might be your issue as well.
Howie is offline
post #7 of 24 (permalink) Old 01-04-2009, 08:15 PM
Boging out
I have a ´93 Wildcat Efi and just measured the fuel pressure and got 2,1 bar = ca. 30psi. It´s very easy to measure the pressure, just take the hose off were it connects to the rail (clutch side and stick a meter in between). If you don´t have a meter you could also take the hose off the other side off the rail and put a bottle under it to see if the pressure regulator is working. You should always be getting some gas flow through the regulator if you´re getting enough pressure. The meter of course would be best.
My best from Iceland, Iceeman...
Iceeman is offline
post #8 of 24 (permalink) Old 01-04-2009, 10:20 PM
Dirtman's Avatar
just to ask a stupid question , but is it possible if the fuel is there just a weak spark ? could this be as simple as a bad coil?
Dirtman is offline
post #9 of 24 (permalink) Old 01-04-2009, 10:21 PM
Dirtman's Avatar
i am having this prob with my 94 ext efi 580
Dirtman is offline
post #10 of 24 (permalink) Old 01-05-2009, 02:06 AM
The pickups on the tank for the fuel can get clogged.
You would have enough fuel flow for low to mid rpm operation, but not enough for high speed.
Has the sled sat for any extended time (year or more without operation)?
post #11 of 24 (permalink) Old 01-05-2009, 08:31 AM
Quoted: 143 Post(s)
Yep the smart valves wont let water pass but will get clogged! Also the fuel pump has a crimped on hose fitting that came loose on mine! Good news is that Auto Zone crosss ref my pump by the numbers on it and they had one in stock for like $75! Just had to use a different fitting on pick up!
kccats is offline
post #12 of 24 (permalink) Old 01-05-2009, 09:24 AM
try putting some Injector cleaner in the gas...and on my buddys 700EFI hes running a higher Octane...u can probably even put a dash of Oil in the gas tank for some extra security against engine failure, and maybe a possible small engine tune up...i run it in every tank of gas i put in my jag along with a dash of injection oil
diez_440jag is offline
post #13 of 24 (permalink) Old 01-05-2009, 09:42 AM
No mixing oil with EFI as it can clog the smart valves and injector nozzles.
post #14 of 24 (permalink) Old 01-05-2009, 06:10 PM
why would it mess it up...doesnt it get injected thru it anyways
post #15 of 24 (permalink) Old 01-05-2009, 06:36 PM
arctic cat
i have the same prob with my 95 ext580efi
580ext is offline
post #16 of 24 (permalink) Old 01-05-2009, 07:32 PM
I will use some of your suggestions when I have a look at mine, and let every one know what I found. I hear that there is a computer program that can scan the engine, and that the wiring harness is available through Arctic Cat. Is anyone aware of such a program?
Howie is offline
post #17 of 24 (permalink) Old 01-05-2009, 09:19 PM
Also does anybody have an idea where I can get the enginespecs for my sled. Wildcat 700 EFI?
Howie is offline
post #18 of 24 (permalink) Old 01-06-2009, 12:56 AM
No, the oil is injected directly into the lower block under the throttle bodies.
post #19 of 24 (permalink) Old 01-09-2009, 09:32 PM
Thanks again RJ. I will let you know how I make out.
Howie is offline
post #20 of 24 (permalink) Old 01-22-2009, 11:15 PM
Dwayne also check the injector sensor. I had a similar problem and I found that the sensor was loose.
Howie is offline
