Old 12-12-2008, 12:35 AM   #1 (permalink)
91renegade
Question has any one ever had there stator repaired
i'm geting tired of buying new stators at almost $600 a pop every arctic cat i have owned has need a stator i put one in my zl 600 last winter and now my wild cat needs one i talked to a friend of mine and he told me about rm stator the will rebuild/repair my stator for $175 has any one hear ever used them before ?
91renegade is offline   Reply With Quote
Old 12-12-2008, 09:47 AM   #2 (permalink)
DFickel
DFickel's Avatar
I was you about 6 months ago and I came to this site with the same question. A guy here called Jerry France hooked me up with a used one with about 1500 miles on it, so insted of 500 for new, I paid like 150, I installed it and the ol zr600 fires right up and hauls balls. I say if your friend do it if he's good at it, it's def worth a try. If not I"m sure we can find somebody here to help out. Good Luck
FDRAGONS, TUNNIN FORKS, AND BEES CANT KILL THEM CATS!
DFickel is offline   Reply With Quote
Old 12-12-2008, 09:53 AM   #3 (permalink)
BC_Dan
Stator Corp does a great job, the wire is heavier gauge so the heat doesn't destroy the stator.
If you go visit ArcticChat, they have a couple of pretty good threads on stator issues. A big one is putting more vents into the stator housing to let the heat out. Some guys space the stator housing out with washers, others have drilled a bunch of holes in the housing to let air in/out.
Good luck!
Old 12-13-2008, 01:21 AM   #4 (permalink)
D&D800
D&D800's Avatar
Stator Corp in Mass is ten times better than RM Stator.
D&D800 is offline   Reply With Quote
Old 10-12-2009, 10:10 PM   #5 (permalink)
Blaine1
I rewind stators (specializing in Cat stators) for $175 and a 2 year warrenty.
Here are a couple of videos to show how to test and remove a stator from a sled:
Stator testing out of a sled
YouTube - Stator Testing a 2 Stroke Stator
Stator testing in a sled:
YouTube - Stator Testing in a sled
Stator removal:
YouTube - Installing a Stator Pt.1 Removing it
Stator reinstall:
YouTube - Installing a Stator Pt.2 Putting Everything Back Together
