Old 03-12-2003, 01:12 PM   #1 (permalink)
RenLan
Question Clutch Spring Advice Needed
I have a 1997 ZR 580 EFI and I was wondering about clutch spring replacements. The sled runs great and clutch engages at 4500 rpm. I have seen replacemet springs on-line and they seem to go by color. If I wanted the clutch to engage sooner (at a lower rpm) what color should I get and what can I expect for performance issues that might make me reconsider. I would like the sled to engage more like my 1995 Wildcat 700 EFI that kicks in about 3500. I dont care about top end speed as I dont go over 70 MPH anyway. (new to snowmobiles and bought both of these sleds just this month)
Thanks much for any comments or suggestions.
RenLan is offline   Reply With Quote
Old 03-13-2003, 02:32 PM   #2 (permalink)
SDlawndawg
The two sleds you own have different torque curves which means the clutching is quite different too. Your 580 probably needs to rev a little higher to achieve the same torque as your Wildcat. I would not reduce engagement RPM since that will create a "bog" when you start out. If you want more of a rip off the start, try putting a stiffer spring in to raise the engagement. 4,500 rpm should be just about right though.
Also, 3,500 RPM seems kinda low for an engagement for a 700 Cat. My 650 Wildcat would engage about 4,800. If you want to replace a primary spring, I would change the one in your Wildcat. If there are many miles on the Wildcat, it could use a new spring and probably everything else in the clutch. I had to rebuild the primary in my 650 about every 1500 miles. Those twin "paintcans" really vibrate the hell out of everything.
SDlawndawg is offline   Reply With Quote
Old 03-18-2003, 11:03 PM   #3 (permalink)
BordnBill
BordnBill's Avatar
I changed my yellow spring which engaged at 4600, to a red spring which engages around 3700. and there is a bog off the start, but I don't normally hammer it off the start. It is good for boondocking. The lower engagement helps your sled not to dig itself in. I like it.
BordnBill is offline   Reply With Quote
Old 07-19-2003, 06:52 AM   #4 (permalink)
zrnewf
ZR700 ROCKIN BABY!
zrnewf's Avatar
The paintcans def vibrate, but I like it, it's rude! and has attitude. the new clutch works great....Im getting a D&D clutch kit for my sled. Should wake it up, my 700 engages at 35-3700. too low, got some bog, so im getting it bumped up!
I may be slow, but im.........Wait a minute, im not slow! Thats why im ahead of you!
me and my sled!
zrnewf is offline   Reply With Quote
