APV adjustment warning!
I own 2 2002 ZR-500s. One has 900 miles, the other just hit 1800.
My last sled was a 2001 with over 2500 miles!
I was just made aware that APV adjustment as well as cleaning is suppose to be routine maintenance. So much for the auto-cleaning system!
Here's how I found out. On my last ride of the year, I hit a very hard drift. My sled then proceeded to stall and run like crap. At first it acted like a fowled plug, since it was close to 40 that day.
What I eventually found out is that the APV actually came into contact with the piston, causing a piece to break off and scuff the piston and cylinder. Needless to say, the motor is in the process of being rebuilt.
I know it's my fault if it is indeed routine maintenance, but I have a problem with something like this happening with less than 2000 miles on the machine! Plus how cheap are these motors built if the piece of metal that is suppose to keep the APV out of the combustion chamber is thin enough that the thing can shoot right through it with the slightest impact?
To make matters worse, my other sled has made similar clinking noise since I picked it up, and my mechanic has also noticed the similar noise on his own 500!
Has anyone heard of a recall on this item by any chance? Is this specific to 500s or is it all APV motors?
Dan
