Old 10-06-2008, 09:05 AM   #1 (permalink)
kilabeez0
kilabeez0's Avatar
sticky secondary
if i take the belt off the motor revs out great. if i put it on and try and run it across the lawn it will bog around 5k rpm and occasionally snap out of it and rev out. if i lift the tail end up and take the load off it will rev out fine. i think the secondary is sticking because she's old and rusty. i used a fine grit sand paper on the shaft and sprayed some rust penetrant on before i put it back on. should i grease it? this is on an 89 wildcat 650.
85 ATC 110 minto
85 ATC 70 stock
85 ATC 70 with oil cooled Lifan 138
02 400ex, tons of mods
87 Yamaha SRV540
02 Suzuki LT50
kilabeez0 is offline   Reply With Quote
Old 10-06-2008, 10:19 AM   #2 (permalink)
BC_Dan
Clutches are designed to run clean and dry. No lubricant. Take a good look at the weights in the primary, you may have one that is damaged or sticking. You could have a bad roller in the primary as well.
If it's been a while, you may want to put a new spring in the secondary, and replace the buttons. Check the helix ramp for wear as well.
Rebuilding the fleet!
Old 10-06-2008, 01:17 PM   #3 (permalink)
The problem is not the secondary.
The primary needs cleaning.
http://www.snowmobileforum.com/engin...ng-advise.html
Old 10-06-2008, 02:38 PM   #4 (permalink)
kilabeez0
kilabeez0's Avatar
i think it's the secondary because i can actually see the secondary sticking. i couldn't get the first one off so i pounded it off, it was rusted on. i bought another used one this weekend and put it on, but i can still see it sticking on the shaft.
85 ATC 110 minto
85 ATC 70 stock
87 Yamaha SRV540
02 Suzuki LT50
Old 10-06-2008, 08:02 PM   #5 (permalink)
JheLrey
JheLrey's Avatar
Had the same issue, it was the secondary.
Old 10-06-2008, 09:29 PM   #6 (permalink)
kccats
It could be just loading up! It might be in the carbs! After it bogs down take a look at the plugs!
Old 10-06-2008, 10:12 PM   #7 (permalink)
Clean it the same way as the primary.
If it still binds, take it apart and use some emory strips and clean the center shaft and the bushing so it slides easily.
Old 10-07-2008, 01:21 PM   #8 (permalink)
kilabeez0
kilabeez0's Avatar
what did you do to fix it?
85 ATC 110 minto
85 ATC 70 stock
87 Yamaha SRV540
02 Suzuki LT50
Old 10-07-2008, 02:17 PM   #9 (permalink)
JheLrey
JheLrey's Avatar
Took it apart, cleaned it. Checked everything over, threw it back together and called it a day.
Old 10-07-2008, 05:57 PM   #10 (permalink)
bdavis1
my 90 wildcat was doing the same thing this summer and i thought it was the clutches i even had kccats come to my house and look at. finally pulled th motor and found a bad reed. one of the steel reed pedals was gone replaced it with boysen reeds and ran perfect ever since.
bdavis1 is offline   Reply With Quote
