09-29-2008, 12:06 PM
96zr580 efi
with engine runing at idel how much smoke is normal and it also drips oil out exhaust the sled has 1,600 mile on it compression is 125 in both cyl engine runs stong
09-29-2008, 02:04 PM
Should stop dripping after it get up to operating temperature.
09-29-2008, 03:33 PM
96 artic cat zr580
i have been running sled for about 45 mins a day for the last three days, and oil still comes out of exhaust, sled smokes not to bad at idle, alot when rpm is up , some say this is the way they are is it, i wouldnt think so
09-29-2008, 04:26 PM
1st Assistant Highjacker
Wait till it gets colder out and then check it out. Also check the color of the plugs to make sure there golden brown.
1996 Arctic Cat Big Bore Mod Sled Bassed on ZR1 chassis(in the works)
1996 Arctic Cat EXT 580 EFI DLX
09-29-2008, 05:27 PM
96 zr580
so the smoke is nomal, the plugs are black not wet more like soot . will the oil coming from the exhaust stop or is there something i can do to stop it
09-29-2008, 05:29 PM
There is not much you can do to stop it. It can also be condansation mixed with sooth from the exaust. Like I said wait till it gets a little colder and see how it runs then. If your plugs are still black after a good run in cold conditions you could be running to rich in oil.
09-30-2008, 08:42 AM
Chech the oil cable setting? At wide open there are lines that should line up! The other thing to check later is the oil consumpsion! 12.5 galons of gas to 1 qt oil is 50-1! When the oil pump goes bad they go full rich! Not saying that is the prob but keep that in mind, if when it gets cold you can't get it to rev out and it loads up???
09-30-2008, 10:26 AM
96 articcatzr580
Thanks ill look at that is it nomal for the sled to smoke at idle not to bad but more when enigine is raced up , as you can tell i really dont know much about sleds i work on many small and big engines ,2 and 4 stroke but this is all new to me thanks jim
09-30-2008, 02:12 PM
It's pretty normal for the engine to smoke at idle, especially in the summer. 2-stroke oil is not very combustible, and will go through the crankcase/cylinders without being 100% burned, especially when the engine isn't working and there is low exhaust velocity. Then the oil, especially at idle, coats the inside of the pipe and can, next time you start it, the exhaust causes even more to migrate to the exhaust pipe, causing the drip.
When it finally snows, top off the oil to the top, take a ride, fill the tank and measure the amount of oil you have used. If it's a lot more than 40:1 to 50:1, like KC stated, the oil pump may be bad. Usually if they are that bad, plugs get fouled big time and you won't be able to finish a day without changing at least one.
Black and dry plugs would indicate a rich mixture, which is perfectly normal when you are running the sled in the summer.
I don't even try to do any tuning in the summer, it's too hit and miss. You have to have cold conditions to make sure your jetting is set properly. I hate waiting, but sometimes that is what you have to do!
Rebuilding the fleet!
09-30-2008, 02:37 PM
96 artic cat
Thanks for your help its really ippreciated jim
09-30-2008, 04:26 PM
Dan, it's an EFI!
Temp will not have as much bearing on this situation.
I would however check that the oil pump is functioning properly.
09-30-2008, 06:23 PM
You still haven't generated enough heat into the engine & pipe to blow all the condensation out!! Don't be so impatient, these things aren't meant to cold idle all the time!! After everything gets warmed up good, those issues will disappear!!
10-03-2008, 09:33 AM
96 zr580 efi
i checked the oil pump seting and its rite, is there away to check pump without the tools needed, also are the chack valves only to keep oil from draining back to the pump , thanks
10-03-2008, 09:35 AM
I can tell you this, I started my '96 580 EFI last night and within a minute you could not see the end of the garage and I had to get out of there for a good 5 minutes till the smoke cleared. These sleds smoke alot especialy after not being fired up for a period of time or after multiple starts of short durations.
10-03-2008, 11:27 AM
I agree that an EFI will compensate for the air/fuel mixture, even in the summer temps. But, temp in this case has a lot to do with it. The pipe temperature isn't hot enough to keep the oil suspended in the exhaust, so it condenses on the pipe and then drips out the exhaust. In the summer, we can't run 'em up to "real" operating temps, EFI or carb, especially at idle. Idle EGTS run in the 500-600 range, WOT EGTS are 1000-1250. At idle the pipe never gets hot enough to "burn out" the oil. My EFI sled and my carb sleds all drip oil all summer long and smoke big time. It goes away when I can get out on the snow.
10-03-2008, 03:01 PM
IDK, mine does not drip any after it gets hot enough that I can not put my hand on the pipes, even at idle.
10-03-2008, 10:12 PM
I started my sled, my Bro's and the "Wife's" sled last night. They were all running at once. You could not see into the garage except for the headlights. You would swear the garage was on fire.
