Old 08-13-2008, 09:25 AM   #1 (permalink)
hopper16
Need help with model year/engine type
i have a 500cc Suzuki engine in my 86 cougar, the crank was bad so i bought a diffrnt. engine that was suppose to be all there but the carbs, turns out he stripped it before he sent it...then he might as well put it in a garbage bag the way he shipped it, oh well, a learning thing. ok problem= my motor S/N is M50-302619, the one i bought is E50-30940. Also the new one has no rotary valve, does that mean ....mix gas/oil?
hopper16 is offline   Reply With Quote
Old 08-16-2008, 06:26 PM   #2 (permalink)
kccats
Susuki didn't have a rotory valve( rotex) but if you are looking at the oil pump and there is a blank on the back you can likly just use yours. What happened to your original engine? Perhaps you should pull them both apart and make one good one?
Old 08-17-2008, 11:32 AM   #3 (permalink)
hopper16
after checking things out, i found out about the oil pump and rotary valve and how they r different, thanks anyhow. The first motor broke the crank, not sure how, the new motor is a older model, and dont have the gear on the crank for the oil pump. So for right now i mix the gas i guess.......right?
