» Site Navigation
» Power Sports Links
Old 07-26-2008, 07:55 AM   #1 (permalink)
Zr 500
anyone know if the rear shock on my '02 ZR 500 is rechargeable...towards the end of the season when you'd sit on the snowmobile the seat would just sink down and not bounce back up but as the weather got warmer it worked properly...thanks
headbanger783 is offline   Reply With Quote
Old 07-27-2008, 12:02 PM   #2 (permalink)
1st Assistant Highjacker
paintballdude05's Avatar
As long as its the stock ZR shock it is. Either Fox or ACT shocks come stock and a rebuildable. Dont just get them recharged get them rebuilt.
1996 Arctic Cat EXT 580 EFI (For Sale)
1996 Arctic Cat EXT Mod Sled (In the Works)
Almost There!
Old 08-19-2008, 12:25 PM   #3 (permalink)
anyone know where i can get a rebuild kit?
Old 08-19-2008, 12:40 PM   #4 (permalink)
Cat has the kits but your better off getting them rebuilt. This way you know its done right and it requires a bunch of special tools along with nitrogen and the corect filling needle. Places like these are the way to go unless your dealer can do them for a comparaible price.
JBShocks snowmobile shock rebuilding
DeyCore Enterprises, Snowmobile Shock Absorber Service and Parts
Almost There!
Old 08-19-2008, 06:01 PM   #5 (permalink)
Just buy a new one for it, or a rebuilt. They are a PITA without the right tools to do the job.
Old 08-23-2008, 08:38 AM   #6 (permalink)
now of a good reliable place to get one from?
Old 08-23-2008, 08:39 AM   #7 (permalink)
headbanger7483's Avatar
know* sorry
I BLEED GREEN
2002 ARCTIC CAT ZR 500
1999 ARCTIC CAT ZL 500efi
1993 SKI DOO MACH 1
headbanger7483 is offline   Reply With Quote
Old 09-08-2008, 02:51 PM   #8 (permalink)
harofreak's Avatar
it turned out, that when i had to change out one of the front skocks on my polaris, a rebuild for my bent shock was going to cost about $250, and i woulda had to wait 6 weeks for parts, so instead i just went to my local dealer and had them order one for me, and it cost $290 for the whole new shock. if you do a lot of jumping or rough trails, u should have the rebuildable ones rebuilt every year or two. here is a good place to order parts for all makes and models, at a decent price.
Babbitts Sports Center | Arctic Cat OEM Parts | Can-Am (Bombardier) OEM Parts | Honda OEM Parts | Kawasaki OEM Parts | Polaris OEM Parts | Sea-Doo OEM Parts | Ski-Doo OEM Parts | Suzuki OEM Parts | Yamaha OEM Parts
harofreak is offline   Reply With Quote
Old 09-09-2008, 09:13 AM   #9 (permalink)
IndianRvrShiver's Avatar
Be very careful of Babbitts!!
See others experiences here.... HCS Snowmobile Forums
Old 09-09-2008, 10:37 AM   #10 (permalink)
harofreak's Avatar
i guess i was just lucky... i ordered a bunch of parts last year, and they arrived on time and correct... but i am open to other suggestions, now that i have read reviews
Old 09-09-2008, 10:47 AM   #11 (permalink)
Brown's Leisure World - Home Page For OEM Cat Parts
Almost There!
Old 09-09-2008, 11:11 AM   #12 (permalink)
anyone know the part number for the shock for a 2002 zr 500?
im not at home to look up the number
I BLEED GREEN
1993 SKI DOO MACH 1
Old 09-09-2008, 09:42 PM   #13 (permalink)
For regular 2002 ZR 500
old p/n = 0703-929
new p/n = 2703-188
p/n for Cross Country suspension sled = 0703-996
Almost There!
Old 09-26-2008, 10:31 AM   #14 (permalink)
those are the part numbers for the front suspension I need the shock in the rear suspension thanks
I BLEED GREEN
1993 SKI DOO MACH 1
Old 09-26-2008, 10:38 AM   #15 (permalink)
0704-712 Shock, Frt Arm-easy Adjust
1704-266 Shock,rear Arm-alum 47mm
Almost There!
Old 10-11-2008, 09:11 AM   #16 (permalink)
ok so here's my next question...before I buy this part. Last winter when it was cold out i would sit on the sled and it would sink to where it normally would but would not bounce back up....when it got warned the rear would boucne up and down just fine....does that mean I should order a new shock for the rear suspension....if so which one front or back...
I BLEED GREEN
1993 SKI DOO MACH 1
Old 10-11-2008, 10:13 AM   #17 (permalink)
Pull out the entire rear skid & go thru it!! You'll be amazed how rusty all the pivot joints/bushings get. Grease 'em up good & then it move much easier!!
Old 10-11-2008, 10:31 AM   #18 (permalink)
You can get your shock(s) rebuilt for about $25-35 each. If the shaft is pitted, they would cost about $50 each on top of that....much cheaper than new.
