Old 06-17-2008, 12:07 PM   #1 (permalink)
700touring
700touring's Avatar
Question charging wildcat
hi. my 96 wildcat 700 touring is charging 13,8v, but when i hit the throttle its stop charging anybody got an idea what the problem is????
jonatan, norway
700touring is offline   Reply With Quote
Old 06-17-2008, 05:14 PM   #2 (permalink)
paintballdude05
1st Assistant Highjacker
paintballdude05's Avatar
What axactly do you mean charging? Like the stator charging the battery or a battery charger? I dont get what you mean...
1996 Arctic Cat Big Bore Mod Sled Bassed on ZR1 chassis(in the works)
1996 Arctic Cat EXT 580 EFI DLX
Old 06-18-2008, 06:14 AM   #3 (permalink)
I assume he means the stator.
Old 06-18-2008, 07:31 AM   #4 (permalink)
You are getting 13.8vdc at idle and it is dropping off as the rpms increase?
Is that correct?
Test the voltage regulator.
Old 06-19-2008, 11:59 AM   #5 (permalink)
700touring
700touring's Avatar
Is that correct?
correct
where is it located
Old 06-20-2008, 07:24 AM   #6 (permalink)
Look for the two yellow wires from the engine. There will be a small boxlike unit attached (usually by the chain case), this is the regulator.
