Old 06-10-2008, 07:10 PM   #1 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Drive Belts
Just a quick one for everyone...
Going to buy a belt for the zrt. Specs from the manual say its #0627-010, 34-36 mm wide by 120-121cm. Is this belt different then other Cat belts with the same specs, like the 0627-012 or the -020, or many many others.
Thanks
Adam
Ad's Cat is offline   Reply With Quote
Old 06-10-2008, 09:28 PM   #2 (permalink)
Might be a different compound.
Old 06-11-2008, 06:26 AM   #3 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Any reason that you can think of, or anyone else that a different compound would be bad in the zrt? Guess i can call the dealer to find out.
Thanks
Ad
Old 06-11-2008, 07:25 AM   #4 (permalink)
Cord count is higher to absorb the additional torque of a triple.
Old 06-11-2008, 07:31 AM   #5 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Sweet, thanks, so i guess any cat triple belt with the same dimensions would be good?
Ad
Old 06-11-2008, 11:01 AM   #6 (permalink)
paintballdude05
1st Assistant Highjacker
paintballdude05's Avatar
The softer the compound the more grip it will have but the faster it will wear out. Yeah thats what it seems like as long as the dimensions are the same you should be fine.
1996 Arctic Cat Big Bore Mod Sled Bassed on ZR1 chassis(in the works)
1996 Arctic Cat EXT 580 EFI DLX
