Old 05-18-2008, 09:48 PM   #1 (permalink)
SShooterZ
Question Belt or clutch issue?
1995 ZR 700
Was playing with it in the garage and noticed that the track engages while at idle. I have the back-end jack-up off the ground, started it up and within about 30 seconds of it running the track started going. Even the odometer read that it was moving.
What do you think would cause that?
1996 Arctic Cat Panther 440 2UP
1996 Arctic Cat 580 EXT EFI
1995 Arctic Cat ZR 700
SShooterZ is offline   Reply With Quote
Old 05-19-2008, 06:17 AM   #2 (permalink)
They do that sometimes. Is your idle at around 1800 RPM's? If not, lower it.
Old 05-19-2008, 03:13 PM   #3 (permalink)
BC_Dan
When idling, the belt is still in contact with the center of the clutch. With the track in the air, there is enough force coming from the clutch to the bottom of the belt to get the track to turn. If it does not try to creep forward when the track is on the ground, it's not a problem. Like SEG said, sometimes lowering the RPM at idle will help, but a bit of track movement when the sled is on a stand is pretty normal.
Rebuilding the fleet!
Old 05-19-2008, 08:16 PM   #4 (permalink)
SShooterZ
Thumbs up
Thanks for the responses guys.
It does idle right around 1800 so that's good.
I was just suprised since my other two don't do it.
Old 05-20-2008, 10:24 PM   #5 (permalink)
TCOLLINS
FORGET WORK- I WANNA PLAY
TCOLLINS's Avatar
Hop on it and pretend you are on the mountains.J/J.
1998 Polaris Indy 500
1996 Yamaha Vmax
1991 Yamaha Phazer II
