Old 05-12-2008, 04:29 PM   #1 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
96 zrt rear...again
So i got the suspension out. Thanks RJ...
I'm going to have to replace the front arm to rail mounting plates cause both sides are completely cracked, looks like impact damage, not sure if you can even buy them separate from the rails. Arms are all rusted and I'm gonna pull the shocks and check them over but then i was thinking...
If too much is wrong, I may upgrade the suspension to the ETT. I've been reading about it on a few other forums. I've found a suspension from a 97 zl440 that looks in good shape. Sounds easy enough although i have no idea where to get the measurements required...
This wasn't in the original plans for this summer but since i have to deal with the suspension anyways...
Any thoughts, ideas, warnings...
Future Sledder
Ad's Cat is offline   Reply With Quote
Old 05-12-2008, 08:12 PM   #2 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Only thing i've been able to find out is that the zl doesn't have the torque sensing link. Doubt this would be a big deal since i'm coming off the stock zrt suspension, but does anyone know if it can be added to this setup?
Future Sledder
Old 05-13-2008, 08:18 AM   #3 (permalink)
Contact this guy for that info;
Snowmobile Fanatics - arcticcatmatt's Profile
Old 05-14-2008, 06:26 PM   #4 (permalink)
cjone782000
cjone782000's Avatar
i have a whole sled for sale...1997 zrt-800 its does need a drive shaft bearing. just throwing it out there. the sled is in plymouth massachusetts. might be better then piecing together a sled
97 Artic Cat ZRT800
snowmobileforums chapter 13 advice giver. 0 credibility
cjone782000 is offline   Reply With Quote
Old 05-14-2008, 07:01 PM   #5 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Thanks, but my engine is strong, i know this sled, and i just got the hood painted.
Good Luck Selling
Future Sledder
Old 05-14-2008, 07:52 PM   #6 (permalink)
cjone782000
Good Luck Selling
LOL thanks. I dont want good luck selling. Hmmmm how about goodluck fixing. so did you find it easy to take apart and fix. rj said for me to fix my bearing its pretty simple. my brother thinks its a bad idea for me to try. especially if i think i fixed it and it breaks again on a canada trip or something. i kinda tried selling it. if someone wanted it bad they would have bought it. i would like a 1000, but mine is good. she has 6,000 miles. i should replace all the bearings anyways.
97 Artic Cat ZRT800
Old 05-14-2008, 08:20 PM   #7 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Haven't really had too much trouble, but i like tooling around. I guess the hardest part will be remembering how to put it all back together . Got all the different parts bagged and took lots-o-photos. My shop looks like a parts warehouse...carbs are out, exhaust is off, seat-n-tank, dash, hood, suspension, next i'll pull the water pump and check the seals there. Prob won't get into the engine, depends how quick everything else goes. I've never tried pulling the driveshaft, so i can't really say how much is involved.
RJ has some good ideas and seems quite knowledgeable from help i've gotten or other posts i've read.
Good Luck Fixing
Future Sledder
Old 05-15-2008, 11:15 PM   #8 (permalink)
Just changing out the drive shaft bearing will require you to remove the pipes so that you can open the chain case. You will also have to take off the secondary unit to make it easier to get at the bearing on that side. Loosen the track all the way and drop the skid and have at it.
Use one of the online microfiche's to show an exploded view of the parts for easier reassembly.
' + objMainFrame.arrApplicationTitle['EN'] + ' -- EMPARTweb*Version 5.2.2* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
Arctic Cat E-Parts Catalogs -- EMPARTweb Version 5.2.2
Old 05-16-2008, 10:30 AM   #9 (permalink)
SkiDooFormulaMX
GO GREEN OR GO HOME!
SkiDooFormulaMX's Avatar
yeah i did mine on my 580 this year, not too bad for my first time.
2003 ARCTIC CAT ZL 600 EFI SS-2700 MILES-GETTING SOME MILD TWEAKING THIS SUMMER
2002 ARCTIC CAT Z 440 ES-622 MILES-MINT, JUST LOOKING FOR SOME STUDS AND FATBOY TORSIONS.
1997 ARCTIC CAT EXT 580 EFI DLX 4000 MILES-SOLD 8/08
1998 ARCTIC CAT ZR 600 EFI-3700 MILES-BUILT-SOLD-9/07
1996 INDY CLASSIC 500 ESR-5100 MILES-SOLD 4/08
1987 SKI DOO FORMULA MX 470-12000 MILES-SOLD 12/07
SkiDooFormulaMX is offline   Reply With Quote
Old 05-17-2008, 07:09 AM   #10 (permalink)
kccats
Hey CJ I picked up my big truck from Ma last summer it wasn't Plymouth but it sounded like it?
By all means do the ETT upgrade! I did my 95 ZRT and Wow what a difference! I did the front too and I must have dropped 50 pounds! And what an improvement!
And all you would need to do is pick up an upgrade kit for bout $100!
Old 05-19-2008, 05:13 PM   #11 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Thanks KC, been reading at arctic chat and got the measures for a 98 zl. I assume the 97 is the same, any idea? Waiting for a post there to confirm, but no takers yet...
You mean an upgrade kit for the front suspension mod? Been reading about that too. Didn't think it was in the budget, but for 100 bucks... Are you just calling it an upgrade kit, as in buy all the parts separate to upgrade or is it actually available as a kit somewhere? Haven't bothered looking into the parts i'd need, but now i just might.
Damn...this'll be a completely new sled by the time i'm done!
Ad
Future Sledder
Old 05-22-2008, 08:57 AM   #12 (permalink)
cjone782000
thanks kc. i hope to have it sold to my brothers friend. lol 800 bucks. any of you guys want it. i'll give it to one of you for 700. i'm not to happy to sell it to this guy. lol. he'll probably hit a tree. i shouldn't say that. bad karma. now he wont buy it and i'll be screwd.
97 Artic Cat ZRT800
Old 05-22-2008, 05:30 PM   #13 (permalink)
paintballdude05
1st Assistant Highjacker
paintballdude05's Avatar
I have already started what is known as the AGLT mod, bassicly instaling 2000+ zr a-arms in the zr1 chassis. To go along with that I got some Fox Floats . But, the arms I got are tweeked and don't fit right . That being said, I got to go borrom somebody's torches to get em back in check.
From what I hear its a hure improvement over stock setup. The only other suspension related mater for me is to find a new rear skid...
Good luck!
1996 Arctic Cat Big Bore Mod Sled Bassed on ZR1 chassis(in the works)
1996 Arctic Cat EXT 580 EFI DLX
Old 06-24-2008, 06:26 PM   #14 (permalink)
Can ZR 580
ad's cat just wondering have you ever had a problem with yours (96 zrt 600) overheating killer hood by the way
Can ZR 580 is offline   Reply With Quote
Old 06-25-2008, 07:31 AM   #15 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Thanks, the hood came out better than i could have hoped for...
Nope, didn't have a problem with overheating, but i only picked up this sled last february. I am losing antifreeze very slowly somewhere, trying to locate that right now actually. I had her out for a few longish runs with a lot of idling as well as low and high speed without a problem. I think i only totalled 150 km on her this past year.
I take it your 580's been running a little warm?
I'd post a new thread, the forums a little slow right now, but quite a few good people are still around to help.
You could check a few things, although this time of year it'll overheat fast.
1. Make sure you have enough fluid. Not sure about the 580, but i'm supposed to tilt the front of the sled up about a foot when i'm checking the level and filling to make sure i get enough back to the rear heat exchanger.
2. Make sure your fluids in good shape. Long shot, but if its really old or for some reason has water in it, could have been freezing on you and creating a blockage.
3. If you want to run it now, fire the sled up and keep touching the rear heat exchanger as the sled warms, if it starts to get warm, then your antifreeze is cycling. I wouldn't run it more than 10 or 15 mins though, especially if it was overheating in the winter.
4. If the heat exchanger doesn't get warm then pull your thermostat and test it. Heat up some water and drop it in, you should be able to see the diaphragm move open. If it doesn't then you'll need a new t-stat.
Just a few things to check but i would post a new thread and you'll prob get lots more help.
Good Luck
Ad
Future Sledder
Old 06-25-2008, 07:54 AM   #16 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Just checked my manual. For most 90-98 liquid cooled models (thats what my manual is for), the t-stat should open at 42 deg C (107 deg F) and close when the liquid temp drops more than 10 degrees.
Future Sledder
Old 06-25-2008, 10:57 AM   #17 (permalink)
paintballdude05
As AD said you could could have a blockage in the lines being a number of things. When filing a sled you should have the front end up in the air more then a foot to get rid of any air pockets back there. You should also run the sled in this position for a litle while being carfull anti-freeze doesn't get everywere.
Old 06-26-2008, 07:00 PM   #18 (permalink)
Can ZR 580
thanx guys but Ive tried it all and it's the zrt not the zr that has the problem...
good on trails and ditches but overheats on the hard pack on the lakes not enough snow being thrown up...my zr 580 no prob on the lake but its picked
Old 06-26-2008, 08:08 PM   #19 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Sorry, haven't had mine on ice yet to test it, and with all the snow we had late in the year, the trails around here were groomed nice not too hard. Threw lots of snow around.
I've read somewhere about putting in extra rads for some "wind" cooling. I guess anyone that runs in the summer with a liquid cooled would have to rig something?
Ad
Future Sledder
