Old 05-10-2008, 06:40 PM   #1 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
96 zrt rear suspension removal...
So...anyone no a good trick to get the second tunnel bolt off for the front rear suspension? With one bolt out completely, the rod that spans the front arm keeps spinning. Will i be turning each a and a little and a little. ...was a great day...got my wifes sled tuned and fogged. Removed her suspension, no probs, gotta go buy some sliders before i re-assemble. Figured i'd get back to mine. The rear tunnel bolts did the same thing but i was able to finally get em off. Tired from hopping from side to side, figured i'd eat and get back at 'em. Hopefully someone hs some good advice...
Thanks
Adam
96 zrt 600 During...
Still workin on it!
Ad's Cat is offline   Reply With Quote
Old 05-11-2008, 12:35 AM   #2 (permalink)
Take a longer threaded bolt an put a nut on it. Screw it in and use the nut to lock it, then take out the other side. Then just unlock the nut and remove the long bolt.
Old 05-11-2008, 07:39 AM   #3 (permalink)
Ad's Cat
A.K.A. adbaker
Ad's Cat's Avatar
Thanks, i'll give it a go this morning. Ran into another problem last night too because of the bonehead that used to own this sled...i'm posting it in the general forum this time.
Ad
Still workin on it!
