How to tell if a cdi box is bad??? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 03-21-2008, 11:18 AM   #1 (permalink)
Question How to tell if a cdi box is bad???
How do you tell if a cdi box is bad? if the sled doesnt start?? thanks
Kaw_rcr is offline   Reply With Quote
Old 03-21-2008, 12:29 PM   #2 (permalink)
Live 2 Ride
Spun222400's Avatar
are you getting spark?
Spun222400 is offline   Reply With Quote
Old 03-21-2008, 01:41 PM   #3 (permalink)
the snowmobile works fine, i just have an extra cdi box and i want to know how to test it , to see if it works.
Old 03-21-2008, 02:21 PM   #4 (permalink)
Swap it onto the good sled and see. Only way to check them. If it doesn't start, it's junk.
Old 03-21-2008, 03:27 PM   #5 (permalink)
FORGET WORK- I WANNA PLAY
TCOLLINS's Avatar
The way I knew mine was bad is that The sled ran like crap. I than took off wires one at a time and realized it was only running on 1 cylinder. Then swapped wires than other side worked. I did have spark on both cylinders but one was very weak. Sled still started right up but didn't run too well(on 1 cylinder). So to test cdi I would unhook each plug wire individually and see if it starts. It will start one 1 wire. If it only works on 1 wire than its probably bad.
1998 Polaris Indy 500
1996 Yamaha Vmax 600
1991 Yamaha Phazer II480
1986 Yamaha SRV 540*Freebee*
Old 01-18-2010, 12:20 PM   #6 (permalink)
tylerbrannam's Avatar
my 1991 Yamaha Phazer II480 drops cylinders at top end i think its the cdi box what do u think every thing is new exept for that
tylerbrannam is offline   Reply With Quote
Old 01-18-2010, 02:26 PM   #7 (permalink)
Blaine1's Avatar
x2. Pretty much the only way...
Wanted: Dead Stators PM me.
Testing Cat triple stators
Jumper wire bypass
Old 01-29-2010, 04:12 PM   #8 (permalink)
well my friend has the same sled and the cdi is just fine what else do u think it might be
Old 01-29-2010, 08:26 PM   #9 (permalink)
How's my taillight look?
You'll have weak or no spark.
razor_burn is offline   Reply With Quote
Old 01-29-2010, 08:31 PM   #10 (permalink)
aks like it runs out of gas good spark other than that im thinking the fuel pump is goin bad
Old 01-30-2010, 06:01 AM   #11 (permalink)
Blaine1's Avatar
Probably not the CDI. Either bad coils (Have you trimmed the plug wire ends?), stator or fuel issue. Check the compression too. Does it do it all the time? Only after the sled warms up? ect..need more info.
Jumper wire bypass
Old 01-30-2010, 09:26 AM   #12 (permalink)
SnoCat800's Avatar
Somewhere I read that the spark plug should always be securely grounded when checking for spark otherwise it could destroy the CDI. Wouldn't that be possible if you just disconnect the plug wire?
1998 Arctic Cat ZRT 800 Studded
1997 Arctic Cat EXT 580 EFI Studded
SnoCat800 is offline   Reply With Quote
Old 01-30-2010, 07:07 PM   #13 (permalink)
the plug wires were not trimed coils are new the stator is new im goin to take off the fuel pump and check it in a friends sled and see what happens
Old 01-30-2010, 10:26 PM   #14 (permalink)
Mad Snowshoveler
jwaldmann89's Avatar
That doesn't really make sense to me...pretty sure CDI boxes just hold a charge and up the voltage, then disperse it at the right time to the coil that up's the voltage more and sends it to the plugs...not sure how having them not grounded to the engine would hurt it, it has a ground coming out of the bottom of the CDI box right to the motor. But I could be totally wrong, this is just my opinion/observations
2004 F5
2004 Yamaha R6 Powercommander
Originally Posted by kccats View Post
Not Bias at all!
jwaldmann89 is offline   Reply With Quote
Old 01-31-2010, 01:06 AM   #15 (permalink)
SnoCat800's Avatar
Come to think of it, pretty sure it say's that in the 90-98 manual. Believe it say's it's "possible". Take your chances.
