Old 03-03-2004, 02:39 PM   #1 (permalink)
Hillbilly800
"faster than YOU"
Hillbilly800's Avatar
top end on F-6??
to all you f-6 riders. what is your HONEST top speed?? i want to know what you guys are seeing out of your f-6's with 1.375" tracks. i get 100-105 tops. crazy low end, but not as much top end as i've been hearing. i have 650 miles on my sled, so it should be good and broken in by now. also, are u going thru more oil than you'd expect to? i use WAY more oil in my 600 than my 800 and alot more than my brother does in his zr 500. let me know what you think. has anyone heard about these sleds using more oil than necessary? sorry, but i havent figured out how many tanks to a gallon, but im pretty sure im using more than i need to. thanks.
~2002 Polaris Edge X 800
twin PSI pipes
SLP boost bottle
144 Woody Gold Diggers
D&D clutch kit~
'04 F-6 EFI SNO-PRO!!!!!!
"the only thing louder than the pipes on a SKI-DOO......is SKIDMAN666's damn mouth"
"I DONT EAT YELLOW SNOW, AND I DONT RIDE YELLOW SLEDS"
Hillbilly800 is offline   Reply With Quote
Old 03-03-2004, 02:52 PM   #2 (permalink)
Cazwell
Team Arctic
Cazwell's Avatar
i have friend with an 04 F7 and it goes through quite a bit of oil he thinks. The dealer said that all of the F sleds really like their oil. Just what i've heard.
04 F7 Sno Pro
99 ZR 700
99 ZL 600
00 ZR 600
99 ZRT 800
~Ride Hard Or Go Home~
~Work Hard - Play Hard~
Cazwell is offline   Reply With Quote
Old 03-03-2004, 05:55 PM   #3 (permalink)
G-ForceJunkie
gone
G-ForceJunkie's Avatar
not my sled - but I know that a friend's F6 with studs radared at over 110mph (not sure of exact number, 114mph comes to mind) (I think this was 1000feet too)
2004 Arctic-Cat Z570
G-ForceJunkie is offline   Reply With Quote
Old 03-03-2004, 06:07 PM   #4 (permalink)
need an f9
need an f9's Avatar
105 sounds alright. my 5 has gone 92 on the digital speedo. My f5 also eats oil like crazy. I'm thinking of buying some amsoil stock
need an f9 is offline   Reply With Quote
Old 03-03-2004, 06:33 PM   #5 (permalink)
drz400
Banned
Turn down the oil. You won't burn as much. There is no way in the world that it went 114 mph in a 1000', it wouldn't go that fast in 10000'.
drz400 is offline   Reply With Quote
Old 03-03-2004, 07:58 PM   #6 (permalink)
phat_cat800
Goin' No Where Fast
phat_cat800's Avatar
My friend has an early build F6 with a 1.375" track and added weight to the secondary will do 102 on the GPS (speedo reading 103). Off the line he gets 1 to 1.5 sled lengths on my 800, they are a very surprising sled.
1999 Arctic Cat ZRT 800
Miles This Year: 1550
Total Miles: 5270.8
phat_cat800 is offline   Reply With Quote
Old 03-03-2004, 09:48 PM   #7 (permalink)
DitchPickle
Firecat Fanatic
DitchPickle's Avatar
Re: top end on F-6??
Top speed will change dramatically according to conditions. Even packed snow vs. ice will change top end by 10 mph.
What are your RPM's at when you are topped out? Most F6's came from AC overreving at ~8100 rpm. You have to get that down to ~7600 - 7700 rpm.<--- If you are over this, you are overeving and losing hp!!
If you feel you are using too much oil, shorten your pump arm 1 turn. You should first figure out your fuel : oil ratio, then adjust your pump accordingly. Consuming too much oil will also rob horsepower.
If you have anymore ??'s, shoot away!
2004 Firecat F6 EFI
DitchPickle is offline   Reply With Quote
Old 03-04-2004, 10:29 AM   #8 (permalink)
Thomcat86
No Luck Racing
Thomcat86's Avatar
i've had my F6 at 108 on the speedo with the 1" track and picks. i also notice the oil consuption. i have an efi, and i heard that they run at like 36:1 ratio, so that may contribute to the oil eating. not sure, just sharing info. oh yeah, and mine had about on it when i did that run. no idea if it will be faster as it gets more mileage, but its plenty fast now.
Drive Hard-Look Good-Be Loud-Get Some
Thomcat86 is offline   Reply With Quote
