95 Powder Special, Spark only with throttle....no spark when throttle released
1995 Powder Special 580 EXT carb. No spark without throttle.
What is up with that? Is that the TPS? I have just changed drive bearings on lower drive. So I had the skid, track, secondary and chaincase apart/removed. I also welded a new motor mount on at the front (old one broke...previous owner).Just got it all back together tried to fire it and no go without throttle....then it fires right up. It will not stay running by itself as it loses spark everytime I let off the throttle.
Thanks again for the replies.
Brad
