Old 02-12-2008, 03:42 PM   #1 (permalink)
threetop20
threetop20
580 ext efi
hey guy i have a 580 ext efi its new to me and one of the injecters must be dirty any way to clean them use injecter cleaner in tank but still don,t work when i put my hand over that side it works great i thought it was the wireing so i change sides the same thing any one know what to clean it with
threetop20 is offline   Reply With Quote
Old 02-12-2008, 10:50 PM   #2 (permalink)
kccats
They can be cleaned with ultrasonic cleaner?
Old 02-13-2008, 04:48 AM   #3 (permalink)
tckitt13
Reading that post hurts me little brain!
tckitt13 is offline   Reply With Quote
Old 02-13-2008, 06:40 AM   #4 (permalink)
threetop20
threetop20
thanks i,ll try that
Old 02-13-2008, 07:27 AM   #5 (permalink)
kccats
What did you mean by hold hand over it or change sides?
Old 02-13-2008, 01:12 PM   #6 (permalink)
tckitt13
X2
Old 02-13-2008, 03:26 PM   #7 (permalink)
threetop20
threetop20
when i hole my hand over the front of the barrel i took the injecter off and i clean it with ultrasonic cleaner make some diffents but not great still bogging out give it the gas fast and it just dies out i must have a bad injecter
Old 02-13-2008, 03:46 PM   #8 (permalink)
tckitt13
It might just be me but I don't have a clue what this guy's talking about half the time
What barrel? Are you carrying a gun too? Oil barrel? Exhaust pipe?
Yah, must be the injector I guess...but IS THERE A CODE????
Old 02-13-2008, 04:08 PM   #9 (permalink)
threetop20
threetop20
its in front of the throttle body it call a the gas chamber and its a 94 there are no codes
Old 02-13-2008, 04:24 PM   #10 (permalink)
tckitt13
No code indicates the fuel injector circuit is OK (although I'm not sure if a bad injector would always show a code). I have looked for over a half hour at two different parts fisches for your sled and can't find the barrel (gas chamber) that you refer to. Pefhaps you could post a picture? Also, proofreading your typing before you post would help us make sense of it easier.
Old 02-13-2008, 04:34 PM   #11 (permalink)
threetop20
threetop20
sorry it on the front of the injectors thats what i call the gas chambers i don,t see any lights fashing no codes
Old 02-13-2008, 08:07 PM   #12 (permalink)
tckitt13
I still have NO idea what he's talking about. Does he mean the intake flanges?????
it on the front
Ouch
Old 02-13-2008, 09:02 PM   #13 (permalink)
paintballdude05
1st Assistant Highjacker
paintballdude05's Avatar
Um, yeah, you're looking for codes on the injectors themselves? You're not going to get any lol. The codes are going to be flashed by a LCD on the ECU. Looking at it(the ECU) from the front, its on the right hand side in the alluminum housing. Its cover by a plastic eye looking thing. The LED is red and should flash once when the ECU is turned on.
1996 Arctic Cat Big Bore Mod Sled Bassed on ZR1 chassis(in the works)
1996 Arctic Cat EXT 580 EFI DLX
Old 02-13-2008, 10:23 PM   #14 (permalink)
tckitt13
Yep, another guy with no Service Manual and no Owner's Manual. No wonder my head hurts! PBDude, did you ever get yours fixed?
Old 02-13-2008, 10:28 PM   #15 (permalink)
paintballdude05
Yep turns out it was a bad ground from the ECU to the frame. The ground had always been there but when I repainted the frame last summer it must of f*** it up. Now its grounded directly to the battary.
Old 02-14-2008, 12:34 AM   #16 (permalink)
I think he means the throttle bodies. (gas chamber)
Old 02-14-2008, 08:09 AM   #17 (permalink)
threetop20
threetop20
yes finally someone that know what i,m talking about when i but my hand over clutch side it runs perfect so i took the injector out on that side an clean it works better but not right has good take off but die out was told the injector is bad on that side also was told that the injector was bad that year 1994 so i just order two new ones . and no i don,t have manual was bought second hand i got it for 500 and its in perfect shape that why i don,t have the manual
Old 02-14-2008, 11:26 AM   #18 (permalink)
tckitt13
Me no undestan how u put han ova thotel bodee when it on sled. part infron of injector huked to intake part bhine throtel bodee shood hav airbox attached if no box hand coveing baral wood choke that cilindar
I M such a tird sometimes
Old 02-14-2008, 01:04 PM   #19 (permalink)
Yes you are!!
Of course, some punctuation would help him too.
manual here;
Power Sports Resource
Old 02-14-2008, 05:13 PM   #20 (permalink)
threetop20
threetop20
yes by choking it i know that it was not getting gas on that side the injector was not doing its job still waiting on new injectors well let you know when they comes in
