need help!!!!!!!!!! 1996 440z - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 20 (permalink) Old 01-16-2008, 04:38 PM Thread Starter
Question need help!!!!!!!!!! 1996 440z
i need help with my 440z.. i was riding it one day and it was goin good and then it just started sounding funny and running like shit so i changed the plugs.. didnt do anything, triead a different cdi unit, nuthin... looked at the fuel system, its all good... im really really stuck on this one.. im thinkin maybe the timing advance b/c it runs fine from 5000rpm and up but below that it runs like shit and has no power and sounds bad... so how is the timing advance run on this.. what does it get its info from.. or is there even a timing advance... ?
cat440 is offline
post #2 of 20 (permalink) Old 01-16-2008, 06:11 PM
red firecat 600's Avatar
sounds like a stator get the specs and test it sounds like the low speed charge coils are bad
The toy box list:
2005 f7 efi sno pro
2005 gsxr 600
1997 zrt 600 12,500 miles and still kickin ass
2003 chevy 1500 toy tower
red firecat 600 is offline
post #3 of 20 (permalink) Old 01-16-2008, 07:20 PM
How do the plugs look? Did you check compression yet?
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #4 of 20 (permalink) Old 01-16-2008, 08:40 PM Thread Starter
compressions good, plugs are coffe and cream color..... if its the stator how much do they cost new about?
cat440 is offline
post #5 of 20 (permalink) Old 01-16-2008, 10:13 PM
i belive on a 1996 you can replace the stator parts you dont need to replace the whole thing so that will save you money and they are availble after market
The toy box list:
2005 f7 efi sno pro
2005 gsxr 600
post #6 of 20 (permalink) Old 01-17-2008, 07:36 AM
Quoted: 143 Post(s)
I believe ther are 3 coils in the magnito, A lighting and a double stack of ignition (high and low) couldn't tell you wich is low though? You will need to pop the flywheel and mark then remove the whole assem, and do some soldering!
kccats is offline
post #7 of 20 (permalink) Old 01-19-2008, 09:40 PM Thread Starter
ok so what arctic cat calls the primary coil is both the high and low or what? and how do I test the stator? what am i looking for? what are th numbers and what wires do i check?
cat440 is offline
post #8 of 20 (permalink) Old 01-19-2008, 09:53 PM
Quoted: 143 Post(s)
Check the parts links and ask Mr Stator!
kccats is offline
post #9 of 20 (permalink) Old 01-20-2008, 11:36 AM Thread Starter
where do i go for mr stator?
cat440 is offline
post #10 of 20 (permalink) Old 01-20-2008, 06:48 PM
http://www.snowmobileforum.com/misc-...inks-here.html
post #11 of 20 (permalink) Old 01-20-2008, 08:15 PM Thread Starter
o what are the tourque specs for the flywheel too?
Work hard... play harder!
1978 Ford f-150 4x4 Super Cab- 351M, 4 on the floor!, Accel ignition... soon to come, 3 inch lift and 33" tires
1996 EXT580- 4" bar riser, Short windshied, soon to come: 136"x2" track, Rumble Pack can, Plastic Skis.
BRAAAAAAAAP!!!
cat440 is offline
post #12 of 20 (permalink) Old 01-20-2008, 08:21 PM
65 ft/lbs
post #13 of 20 (permalink) Old 01-20-2008, 09:01 PM Thread Starter
thanks.. hopefully thats whats rong.. then i can finally fix it and focus on the looks... and maybe even win sled of the month!!
BRAAAAAAAAP!!!
cat440 is offline
post #14 of 20 (permalink) Old 01-21-2008, 07:19 AM
GO GREEN OR GO HOME!
SkiDooFormulaMX's Avatar
my girlfriends sled did that, ran like crap below 5 but great above, it was the carbs.
2004 F7 SNO PRO 3853 MILES, ODS CLUTCHING, GEARED, BMP PIPE, D&D Y PIPE, SLP INTAKE
2003 F5 STANDARD 2201 MILES
2002 Z440 ES 2650 MILES
SkiDooFormulaMX is offline
post #15 of 20 (permalink) Old 01-21-2008, 12:22 PM
harofreak's Avatar
sounds like a plugged high speed jet
harofreak is offline
post #16 of 20 (permalink) Old 01-21-2008, 04:42 PM Thread Starter
ive takin both carbs apart and put new jets in and still nuthin... they have both been dissassembled and thouroughly cleaned several times.. so i know its not the carbs....
BRAAAAAAAAP!!!
cat440 is offline
post #17 of 20 (permalink) Old 01-22-2008, 05:58 AM
Quoted: 143 Post(s)
But did you dissasemble and soak them over night?
kccats is offline
post #18 of 20 (permalink) Old 01-22-2008, 07:13 PM Thread Starter
we only have carb cleaner in the aresol can... so i didnt get to soak it... but im sure its electrical cuz it was doin it then it quit for like 2 weeks.. then it started bein dum again.. but its not as bad as it was... and it it was the main jet it wouldnt run good at full throttle... it runs fine at W.O.T.. and weve been through the carbs so many times we would have found it by now if it was in the fuel delivery...... o and it sounds like its only hittin on one cylinder most of the time below 5000 but sounds great above...
BRAAAAAAAAP!!!
cat440 is offline
post #19 of 20 (permalink) Old 01-23-2008, 07:10 AM
Quoted: 143 Post(s)
Well good luck and keep us posted on what you find? Hey what size pilot jets does it have in it?
kccats is offline
post #20 of 20 (permalink) Old 01-27-2008, 09:05 PM Thread Starter
ive got 30 pilots in it and 280 mains..... i think its a fuel problme now tho... it sounds like its only hittin on one cylinder below 5000... then above 5000 it runs fine... so maybe pilot or low speed screw is wayyy outta wack?? i pulled apart one of the carbs yesterday and took out the pilot and its not plugged and size 30 sounds about right... but the low speed air screw seemed wayyy to far out.. so maybe the one side was too rich or sumthin. im waitin for a new starter cup right now but i should be able to get that done by about tuesday or wednesday then i can start it and see if its carbs er what...
BRAAAAAAAAP!!!
cat440 is offline
